Guest aspire Posted November 14, 2012 Share Posted November 14, 2012 hi guys, just a quick question im looking an answer for. my car is having the new LSD diff being fitted, its a NA manual 5 speed, was auto but has been converted to manual, last year before conversion was done noticed what i can only describe as a rear wheel bearing rumble/humm. now i have supplied 2 new rear bearings for the garage doing the diff work, but they can hear the noise but have said no play in wheels... could it be the diff? which is good as i am replacing it, or could it be anything else??? very intrusive noise, but im at a loss now, any help please guys... Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2012 Share Posted November 14, 2012 It can't really be many things back there and if its not a wheel bearing then its either the diff or a cv joint, more likely the diff. Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 14, 2012 Share Posted November 14, 2012 Cheers dunk. thats what i was hoping for. could a bearing fail with out any movement on the wheel... Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2012 Share Posted November 14, 2012 They shouldn't really, what do they rotate like, do they feel smooth ? Your garage could always put a stethoscope on the diff and hubs Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 14, 2012 Share Posted November 14, 2012 They run smooth. i will speak to garage. i changed the auto diff fluid last year. there was no debris or metal when it was drained Quote Link to comment Share on other sites More sharing options...
Iky Posted November 15, 2012 Share Posted November 15, 2012 Cheers dunk. thats what i was hoping for. could a bearing fail with out any movement on the wheel... Not insulting your garage but are you sure they checked it with the handbrake off? Could also be loose hubnut. They need torqueing to like 300nm which is a hell of a lot. Best way to check would be handbrake off and brake caliper pads out imo. Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 15, 2012 Share Posted November 15, 2012 just an update, 100% sure not the rear wheel bearings, they are changing diff and putting on another set of drive shafts, should know more tomorrow Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted November 15, 2012 Share Posted November 15, 2012 When one of my rear bearings went there was no movement, just a grumble. Was checked out by Paul Whiffin and a replacement hub solved the problem. So it was the bearing. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 15, 2012 Share Posted November 15, 2012 just got a fancy guage from a jaguar dealer and it says the baring is dieing so that will be that, onward Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 18, 2012 Share Posted November 18, 2012 quick update, the new LSD diff makes such a difference to the car, much more entertaining to drive on the damp roads!! next job swap out rear sub frames and replace with complete set up from craig.... with new(ish) bearings allready fitted....many thanks Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 18, 2012 Share Posted November 18, 2012 Has your noise now gone ? Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 18, 2012 Share Posted November 18, 2012 hey dnk, no, the bearings are on the way out, going to do a hub swap now. Quote Link to comment Share on other sites More sharing options...
