_Shane_ Posted November 13, 2012 Share Posted November 13, 2012 Guys i am looking at purchasing an alloy oil breather tank for my supra. The tank i am looking at has 2 fittings on it which are interchangable (10mm or 15mm) My cam covers have -10an Earls fittings on these. My question here is will the braided hose that i purchase to suit the -10an cam cover fittings be able to be attached / secured on the brether tank with the 10mm / 15mm fittings? Hope ye understand what im trying to say Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted November 13, 2012 Author Share Posted November 13, 2012 found it online http://www.precisionenginetech.com/tech-explained/2009/05/20/an-hose-and-an-hardware-part-1/ Quote Link to comment Share on other sites More sharing options...
Callaway Motorsport Posted November 14, 2012 Share Posted November 14, 2012 Guys i am looking at purchasing an alloy oil breather tank for my supra. The tank i am looking at has 2 fittings on it which are interchangable (10mm or 15mm) My cam covers have -10an Earls fittings on these. My question here is will the braided hose that i purchase to suit the -10an cam cover fittings be able to be attached / secured on the brether tank with the 10mm / 15mm fittings? Hope ye understand what im trying to say No... -10 is not 10mm, it is a different size. You will need to fit adapter fittings on to the catchtank (fitting which fits the catchtank --> turns into -10 male -10 fittings on covers) we can supply you an alloy catchtank (polished) and hoses made to your spec, which will all fit. In the end, try and find a catchtank which makes use of all the same fittings everywhere, so on the tank as well as on your covers (-10AN) Quote Link to comment Share on other sites More sharing options...
