supra-ireland Posted November 13, 2012 Share Posted November 13, 2012 I'd be grateful if someone could tell me the part number for the blanking button in the attached photo. I previously tried unsuccessfully to order one from Toyota. I brought the car over to the garage and showed them but the part that turned up was the wrong one. Cheers... Quote Link to comment Share on other sites More sharing options...
Nic Posted November 13, 2012 Share Posted November 13, 2012 I *think* this is the correct one but best double check with the dealer. http://img571.imageshack.us/img571/2432/picture1ex.jpg Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 13, 2012 Author Share Posted November 13, 2012 I *think* this is the correct one but best double check with the dealer. Thanks Nic, I'm not sure but I think that may be the one I got before that was incorrect. I might just take a chance and order one from Toyota, it's not like it's an expensive part. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 13, 2012 Share Posted November 13, 2012 I'm pretty sure the part number I posted above is the correct one, Toyota do blanking covers for the 3 holes underneath the stereo (shown on pic below), it might be one of these that you got before. http://img341.imageshack.us/img341/2163/picture1hg.jpg Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 14, 2012 Author Share Posted November 14, 2012 I rang my friend in Toyota Ireland there and they said that part is no longer available. Can anyone suggest an alternative source? Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 19, 2012 Author Share Posted November 19, 2012 bump Anyone got a notion where I might be able to get one of these blanks? Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 19, 2012 Share Posted November 19, 2012 (edited) Try Keron on here, he breaks mkiv's, in the traders section Extreme Performance Edited November 19, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
keron Posted November 19, 2012 Share Posted November 19, 2012 I've never seen a blank. That's a uk dash panel that's been hacked below... The hole you have is for the headlamp beam adjuster... Quote Link to comment Share on other sites More sharing options...
Nic Posted November 19, 2012 Share Posted November 19, 2012 bump Anyone got a notion where I might be able to get one of these blanks? You could either source a j-spec ignition panel with just a single hole or you could source a headlight adjuster switch to put in the hole. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 20, 2012 Share Posted November 20, 2012 I should have a good J-spec panel here if you want it bud. Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 20, 2012 Author Share Posted November 20, 2012 I've never seen a blank. That's a uk dash panel that's been hacked below... The hole you have is for the headlamp beam adjuster... The car in the photo is a j-spec. You could either source a j-spec ignition panel with just a single hole or you could source a headlight adjuster switch to put in the hole. Thanks. I should have a good J-spec panel here if you want it bud. Do you have a photo of it? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 20, 2012 Share Posted November 20, 2012 The car in the photo is a j-spec. Keron's right the ignition panel on there is from a UK Supra which has the extra hole for the headlight hight adjuster. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 20, 2012 Share Posted November 20, 2012 Do you have a photo of it? Will get one for you tomorrow if that suits? Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 20, 2012 Author Share Posted November 20, 2012 Keron's right the ignition panel on there is from a UK Supra which has the extra hole for the headlight hight adjuster. Ah right, I guess a previous owner must have fitted a UK panel to the J-spec. Will get one for you tomorrow if that suits? Yeah, that'd be sound, thanks. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 21, 2012 Share Posted November 21, 2012 Bad news I'm afraid mate, at some stage I seem to have chewed a piece out of that particular panel in order to get it to fit around the roll cage. THEN I had the presence of mind to take it off and store it safely. Sorry for wasting your time. Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted November 23, 2012 Author Share Posted November 23, 2012 Bad news I'm afraid mate, at some stage I seem to have chewed a piece out of that particular panel in order to get it to fit around the roll cage. THEN I had the presence of mind to take it off and store it safely. Sorry for wasting your time. Sorry, I'm only seeing this now. That's no problem. Quote Link to comment Share on other sites More sharing options...
