Recaro seat rails
safcdixon
As joe has said, you can fab the stock rails to fit, but its a major pain in the hole.
You need to get hold of a seat of Stock Recaro Rails which will fit perfect, but there are rare as rocking horse poop, or use Bride RO rails, these fit perfect also but are about £200 each, not including delivery :(
The bride rails are not only expensive but also rare, the only place I know that sells them with them in stock is RHD Japan. As mentioned you can play with the stock rails a bit to get them on, if you are tall it will be a ball ache though because you will sit quite high unless you properly cut them up.
