Guest T-I-M-O Posted November 11, 2012 Share Posted November 11, 2012 Hi , since I've removed the throttle body to change the plugs car doesn't run, although it did for the first 5 mins after putting it back together, it was running on choke then started coughing and spluttering , now won't start , I noticed no fuel pump so done the mod on fuel pump ecu but still noting , can hear fuel in the rail and I do have a week spark Can anyone mention anything to check, thanks Tim Quote Link to comment Share on other sites More sharing options...
Noz Posted November 11, 2012 Share Posted November 11, 2012 More info needed. Has everything been connected again properly, have you maybe disturbed some of the ignition? Quote Link to comment Share on other sites More sharing options...
Guest T-I-M-O Posted November 11, 2012 Share Posted November 11, 2012 All seems as it was Quote Link to comment Share on other sites More sharing options...
listy Posted November 11, 2012 Share Posted November 11, 2012 (edited) Maybe you disturbed something? Did all the HT leads go back on the right plugs? Edited November 11, 2012 by listy (see edit history) Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted November 11, 2012 Share Posted November 11, 2012 Check your leads, check all electrical connections Did you get any water anywhere near the spark plug area, as in did you clean around the area at all Did you remove the throttle body totally or just slide it, either way there are 2x vacuum pipes underneath, did you reconnect them or pull them off by mistake When it was running for the couple of minute, was it running smooth or misfiring Is there any chance you bumped the end of a plug while putting them in and closed a plug gap Quote Link to comment Share on other sites More sharing options...
Nic Posted November 11, 2012 Share Posted November 11, 2012 (edited) You may just have flooded the engine, try tuning it over with your foot on the accelerator flat to the floor - hold it there don't pump the pedal - if it is flooded it should fire up after a few seconds. Edited November 12, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest T-I-M-O Posted November 12, 2012 Share Posted November 12, 2012 Check your leads, check all electrical connections Did you get any water anywhere near the spark plug area, as in did you clean around the area at all Did you remove the throttle body totally or just slide it, either way there are 2x vacuum pipes underneath, did you reconnect them or pull them off by mistake When it was running for the couple of minute, was it running smooth or misfiring Is there any chance you bumped the end of a plug while putting them in and closed a plug gap Was running smooth , sounded like it ran out of fuel, I've put in 15 litres and can hear fuel in the rail, is there a solenoid anywhere for fuel cut Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 12, 2012 Share Posted November 12, 2012 vacume leak! mine done the same, seemed to run fine for a few mins then the revs started to bounce then spluttering untill it cut out then would not start. check all vacume lines. Quote Link to comment Share on other sites More sharing options...
