Samurai 20V Posted November 11, 2012 Share Posted November 11, 2012 http://www.supraforums.com/forum/showthread.php?683865-USDM-BPU-vs.-JDM-BPU Opinions? I assume the UK Spec is the same as the US Spec? Quote Link to comment Share on other sites More sharing options...
listy Posted November 11, 2012 Share Posted November 11, 2012 After reading that, may just have to source some USDM turbos Not sure if the uk turbos handle high 400s or not. B But then, most go single if looking for that much. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 11, 2012 Share Posted November 11, 2012 US and UK turbos are the same. The Yanks highly inflate their BPU figures. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted November 11, 2012 Share Posted November 11, 2012 The yanks highly inflate all their figures! Quote Link to comment Share on other sites More sharing options...
Nic Posted November 11, 2012 Share Posted November 11, 2012 (edited) US/UK turbos (CT12B) have smaller turbine wheels and narrower shaft/bearing diameter compared to the J-spec turbos (CT20A). http://www.turbointernational.com/images/catalog-pdf/Catalog-Toyota.pdf Edited November 11, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Guigsy Posted November 11, 2012 Share Posted November 11, 2012 All I know is I went head to ahead with a chap whose name I don't remember at thunder road. My uk bpu auto vs his jspec bpu auto. Almost the same mods... We were both surprised how easily I pulled away on the 2nd tubby. 1st tubby wasn't much different And I too highly doubt the 410 wheel bhp comment. More like fly bhp Quote Link to comment Share on other sites More sharing options...
tony tt Posted November 11, 2012 Share Posted November 11, 2012 And I too highly doubt the 410 wheel bhp comment. More like fly bhp Agreed. Mind you it's not worth the hassle of getting into a debate with them on this as they don't handle criticism very well at all. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 11, 2012 Author Share Posted November 11, 2012 So the UK spec is faster than the J Spec? I read on here before the power/torque figures are more or less the same on the 2.. Quote Link to comment Share on other sites More sharing options...
Mario Posted November 11, 2012 Share Posted November 11, 2012 Nic US/UK turbos (CT12B) have smaller turbine wheels and narrower shaft/bearing diameter compared to the J-spec turbos (CT12A). http://www.turbointernational.com/im...log-Toyota.pdf ^^Aren't the JDM spec turbo's the CT20A's and the CT12A used in the 1JZ-GTE? I'm confused now. @OP The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese). Additionally, the export-exclusive CT12B turbine received more durable turbine housings and stainless steel turbine and impeller fins. In my understanding a safe boost level for the ct20's would be considered at 1,2 bar and for more reliabillity 1 bar. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 11, 2012 Share Posted November 11, 2012 ^^Aren't the JDM spec turbo's the CT20A's Typo should have read CT20A Quote Link to comment Share on other sites More sharing options...
Mario Posted November 11, 2012 Share Posted November 11, 2012 ^^No problem Nic, your typo made me ditch in the books again;) Quote Link to comment Share on other sites More sharing options...
