Warning lights on. (Problem solved).
Kaan W
  • Replies 56
Have you moved the car since the gearbox went in?
Also, did you start it with the odo disconnected?
I have moved it backwards and forwards a couple of times on the drive but not driven it properly. Everythings been connected before start up.
- - - Updated - - -
It's really sensitive so if's worth a check
Ok i'll check now...
I was gonna say airbag warning, but if it was connected, I'm stuck :)
The air bag light has always been on since I got the car. Dont know if its disconnected or not but the chap I bought the car off filled the petrol tank up for me to say sorry he couldnt get the light switched off...
- - - Updated - - -
hmmm, i'm not sure what else causes the handbrake light to come on, the connector on the handbrake is properly on isn't?
It should be, I have had the gear surround off a couple of times is it possible that its come off or is it under the car?
Try this for the airbag light if you haven't already:
http://www.mkiv.com/techarticles/airbag_light/airbag.htm
I'm sure there is a connector near the gear surround for the handbrake light, could've bin knocked?
Ive mailed Ryan to see if this is something he can see through the syvecs or not.
- - - Updated - - -
have you taken the level sensor out the brake resevoir when you done the loom tuck??
I took the lead off the sensor and put back on but havent removed the actuall sensor itself.
ok its not that then! Ermmmm your not being silly and leaving the door open are you?
Bonnets open but thats it but I got someone to press the white switch thing down and its still there. Unless I didnt connect the wire back up properly to the bottom of the bonnet switch cause its a strange one to put back together. Would the bonnet switch cause the lights?
Was it not on before? because my triangle is on all the time! idoes it flash when you press the overdrive button? but also stay on constant when overdrive is off
On the second day of driving the car I noticed the sqaure triangle flashing and staying on after heavy boosting until engine switched off then on again. Not sure when in overdrive would I need to be driving or can I test this in neutral with engine running?
mine is the same im sure its something to do with the autobox ecu and syvecs being linked, maybe wrong on that but my triangle is on for some reason like that, just cant remember. no try it in neutral should flash when on and stay on when off! might be the other way around :D
mine is the same im sure its something to do with the autobox and syvecs being linked, maybe wrong on that but my triangle is on for some reason like that, just cant remember. no try it in neutral should flash when on and stay on when off! might be the other way around :D
Ok i'll try that tomorrow :) But the handbrake lights still on :confused: And this being on will cause the red triangle to be on also....
I'll see if Ryan can see if everythings running properly then if it is im not bothered about a light :)
Was it not on before? because my triangle is on all the time! does it flash when you press the overdrive button? but also stay on constant when overdrive is off.
Mine does this but cant actually remember why, ill have to ask lee again.
Because the sub-tps and motor actuator for the traction control has been removed. :)
