mellonman Posted November 9, 2012 Share Posted November 9, 2012 my seimens deka 650 or 630 as stated,are running my 67mm single turbo with 523bhp 1.3 bar at 80% duty but these are top feed with need rail Link to comment Share on other sites More sharing options...
Guest Budz86 Posted November 9, 2012 Share Posted November 9, 2012 Budz - pm me as I may be upgrading to 800's so my sard 650's could be available Cheers John, deffo interested and as you say, not needing these till Feb/March really. Will have a catch up at BW mate. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted November 9, 2012 Share Posted November 9, 2012 Speak to Ryan about injector size, 650cc is enough to support a 61-67mm single turbo, 800cc would be overkill with hybrid turbos, they'd need to be run at low duty levels which could make them difficult to accurately control. Useful to know this mate, didn't realise that. I assumed the lower the duty the better. Do you have a list of 650 drop in's by any chance? Only know of Sard and PE so far. Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 Sorry Sheefa - I thought you needed them pronto - may be a while before I upgrade and I know dean is probably not in a rush No worries mate. I'm not sure I my plans yet anyway, too much too soon maybe. Link to comment Share on other sites More sharing options...
Wez Posted November 9, 2012 Share Posted November 9, 2012 If your going to be running a Syvecs go with PE 800cc drop-ins, also with the PEs you don't need to worry about a resistor pack as they are high impedance, some other drop-ins are low impedance and will require a resistor pack, for me that's something else to go wrong and extra wiring and money As for rest of fuel system I would leave the stock reg in place, fit a fuel dampener bypass and swap the pump, you could go either Walbro 255, Bosch 044 or the newer larger Walbro, I only have experience of the older 255lph Walbro and the Bosch 044, the Bosch 044 is a large noisy begger but it certainly does the job. The Walbro 255lph pumps have been known to run on motors up to 600hp so will be more than up to the job of your hybrids, plus they are easy to fit without having to mod the pump hanger Link to comment Share on other sites More sharing options...
Hellstrom Posted November 9, 2012 Share Posted November 9, 2012 (edited) about the size on a 6 cylinder engine you can use a rule of thumb that 1bhp=1cc flow from the injector that is at 100% duty cycle using normal fuelpressure. So in other words 650 injectors=650bhp @ 100% duty cycle and so on. you dont want to be to cheap on the tollerance. injectors are design to run @ 80% duty cycle to get the best mixture. in this modern times its almost "the bigger the better" and its pretty much true as modern injectors are well designed and still provide good mixture even at low duty%. Injectors dont usually cost more the "bigger" they are, mostly pretty much the same price (unless you are going WAY bigger then what the regular market is providing) i don't see any disadvantage to use 800cc over 650cc. (unless your mapper says a certain brand is verry hard to map on low load and medium load) Edited November 9, 2012 by Hellstrom (see edit history) Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 If your going to be running a Syvecs go with PE 800cc drop-ins, also with the PEs you don't need to worry about a resistor pack as they are high impedance, some other drop-ins are low impedance and will require a resistor pack, for me that's something else to go wrong and extra wiring and money As for rest of fuel system I would leave the stock reg in place, fit a fuel dampener bypass and swap the pump, you could go either Walbro 255, Bosch 044 or the newer larger Walbro, I only have experience of the older 255lph Walbro and the Bosch 044, the Bosch 044 is a large noisy begger but it certainly does the job. The Walbro 255lph pumps have been known to run on motors up to 600hp so will be more than up to the job of your hybrids, plus they are easy to fit without having to mod the pump hanger Cheers Wez and thanks for the advice. Don't you mean the Walbro 400 or 450 though pal? Isn't the 255 the smaller type fit for max of BPU only? I spoke to Lee who thinks upgrading now whilst I'll be on BPU for a while might be a bit too much. The pump could do with a change certainly, but maybe leave the injectors for now. I am negotiating on some drop in high imp 650s so you never know Whifbitz do the dampener bypass for £70 so that's all good. Link to comment Share on other sites More sharing options...
Hellstrom Posted November 9, 2012 Share Posted November 9, 2012 if you are running 460bhp on stock 440cc injectors you are pushing the limit (iam asuming using higher fuel pressure to take the verry last possible power from the 440cc) Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 That was what the Supra was dyno'd at yes. However, I want the MAXIMUM SAFE power with the 440's. Am still looking into decent drop-ins and believe I may have a deal on Power Enterprise 650cc SH650A Injectors Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 Parry - clear your inbox mate Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 FYI - looked at flow tested and most reputable UK companies clean and test at £12-£15 per injector. With VAT and Postage on top you're looking at between £90-£110. Would there ever be a need to flow test NEW injectors? Surely it's a good safety measure too? Link to comment Share on other sites More sharing options...
johnny g Posted November 9, 2012 Share Posted November 9, 2012 Ask Ryan or Lee about upping the base fuel pressure to get more out of the 440's Link to comment Share on other sites More sharing options...
letmeshowyou Posted November 9, 2012 Share Posted November 9, 2012 Personally I wouldn't be running even as high as 1.2 bar on Hybrids and stock injectors. I couldn't believe the duty figure on Dean's 550's with hybrids! Link to comment Share on other sites More sharing options...
drift_bear Posted November 9, 2012 Share Posted November 9, 2012 I run 550cc injectors on my BPU+ Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 650's have got to be the way to go it seems. Good bit of future proofing up to circa 600bhp and drop ins. Right, onto the purchase! Link to comment Share on other sites More sharing options...
imi Posted November 9, 2012 Share Posted November 9, 2012 Thanks all and yes Imi will look at flow testing for sure if SH, not worth risk otherwise. Got a few options, just need to speak to Lee about which route to take. Bloody expensive things arent they! Don't skimp on parts like these - it works Out cheaper and more convenient in the long run. Link to comment Share on other sites More sharing options...
Chris Bailey Posted November 9, 2012 Share Posted November 9, 2012 In dads supra he has SARD 650cc Drop-ins and they work fine at 550bhp, But Ryan G said they are at 90% duty cycle. I found that odd considering a98malcolm is running 649bhp(I think) with the same injectors. Link to comment Share on other sites More sharing options...
Sheefa Posted November 9, 2012 Author Share Posted November 9, 2012 I won't be skimping Imi rest assured on that, just trying to balance up where I'm going with the car in future and what my power needs are right now. Link to comment Share on other sites More sharing options...
