Josh42 Posted November 8, 2012 Share Posted November 8, 2012 Hi all, Recently done a Auto-Manual conversion and tonight my clutch pedal kept sticking down to the floor. Any ideas? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 8, 2012 Share Posted November 8, 2012 My money would be on...You either didn't bleed the system properly, it has a leak or there is something wrong with the seals in your master or slave cylinders. What brake fluid did you use? Quote Link to comment Share on other sites More sharing options...
Josh42 Posted November 8, 2012 Author Share Posted November 8, 2012 I used motul Dot4. It was fine until today, seems strange. System bled well with no air coming through.... Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 8, 2012 Share Posted November 8, 2012 I had a tiny leak from the brake line connector on the side of the master cylinder, it worked itself loose to the point where it suddenly dew in a load of air and the pedal stuck down. Check all the joins and the bleed nipple first. Obviously also check that the level of the fluid in your master cylinder hasn't changed. If the rubbers in the master/slave have gone, it's not too bad a job. The rebuild kits from toyota are only around £35 each, providing the cylinder isn't scored to buggery! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted November 8, 2012 Author Share Posted November 8, 2012 Excellent! Thanks mate:) Quote Link to comment Share on other sites More sharing options...
