Black_Supras 1000 HP Big Single Build - Fully Build Engines - !!! PIC HEAVY !!!
Black_Supra
  • Replies 330
are you going to brace your manifold with that massive turbo on it? if so where are you bracing to?
I think about it ... its a Manifold from Paul with 4 mm thickness and i think it`s not really necessary cause the stock kits of Paul doesn`t even come with a bracking but i maybe will do it ... manifold + turbo weight unbelivable 29.2 KGs
  • 2 weeks later...
Nice updates !!
How did you find splitting/painting the headlights ? I have to do mine soon :)
It`s not that hard, did this a few times more before ;)
Heat it in the kitchen around 10-15 mins on 100°C, then start in the inner corner with a scriver drew or something like that to split them ... when you splitted the inner side the rest is really easy, just pull a little bit.
I painted them with normal spray paint...
and after all you put them back in the oven and heat them up ;)
I will attempt this very soon :) Was it satin (finish) paint ?
  • 2 weeks later...
