Black_Supras 1000 HP Big Single Build - Fully Build Engines - !!! PIC HEAVY !!!
Black_Supra
1035 HP & 971 NM
FIRST STARTUP VIDEO - SUBSCRIBE! ! !
FIRST STARTUP VIDEO - SUBSCRIBE ! ! !
Hey Guys,
my name is Fabian, 22, coming from Germany.
I bought my Supra two years before (2010) from JM-Imports Germany as totally stock ...
and built it to BPU in the first Winter 2010/2011.
Had a lot of fun with the car in season 2011 and for Winter 2011/2012 i changed a lot of worn parts as clutch, brakes, brake booster, gauges and took the engine bay to a new level as folllows ... (Photoshooting-Photos - Cover Car of the German MKIV-Group - http://www.mkiv.de)
Here you can see the actual Spec-List:
Engine:
HKS SSKV BOV
HKS RS Kit
HKS Air-Filter
Greddy Radiator Pipe
3” Downpipe
3” Nur Spec Catback
Custom Airbox
Cooling Plate
Irridium Denso IK22
Electronics:
APEXI AVCR @ 1,2 Bar
HKS SLD Typ 1
Greddy Fuel Cut Defencer
HKS Turbo Timer Typ 0
Defi 60 mm Boost Gauge
Defi 52 mm Oil Pressure
Defi 52 mm Fuel Pressure
Defi 52 mm Exhaust Temp
Defi 52 mm Oil Temp
Defi 52 mm Water Temp
Cooling:
Toyosports 2,5” FMIC
Racimex 19 Row Oilcooler + Thermostate
Injection:
Walbro 255 LPH
Brakes:
Front D2 Big Brake 356 MM 8 Pod + Flex
Rear EU Brake - EBC Pads + Flex
Suspension:
D2 Street Coilovers
Cusco Strut Bar
Body:
Greddy Spoiler Lip
TRD Wing
Facelift-Style Headlights
Dotz GTR 19" Rims, Fronts 8,5”, Rears 9,5”
Pirelle Pzero, Front 235/35/19, Hinten 265/30/19
Interieur:
TRD 320 KMH Tacho
TRD Gearknob
Recaro Seats
Now it`s time for something new, want to go for a "big" Singleturbo, means complete build Longblock - 74/75 MM Turbo - 1200 CCM Injectors or maybe bigger - GSC S2 Cams - upgraded intake Plenum - RPS TRIPE CARBON CLUTCH - AEM V2 - and many more!
The Rebuild will take a long time(i think about 2 whole years) as i don`t have that much time ... this way i can think about each mod a long while :p
- - - Updated - - -
I was a lucky guy and grapped some nice parts as follows:
- Garage Whiftbitz Twin Wastegate Manifold
- 2 * Turbosmart Comp Gate 40
- 3" Down & Midpipe (just for testing) - going for 4" and open Wastegates
- Titan Motorsport Twin-Feed Fuel Rail
- Bosch 1200 CCM Injectors
- Fuelab FPR
- AEM Wideband
- HKS Cam Pulleys & Pulley & Cover
- Greddy Pulleys
- Superspark Coil Packs
- Garage Whiftbitz Turbo Heatshield
- Garage Whiftbitz Turbo Oil Feed & Drain Lines
Edited by Black_Supra (see edit history)
  • Replies 330
  • 2 weeks later...
Purchase the turbo with a T4 1.00A / R housing. I go with the 78mm compressor wheel and the Spools really good and has neat power.
Greetings from Germany to
Ordered this sweet Turbo @ Boost Lab:
BL375R
Compressor: 74.7 mm BILLET
Turbine: 83.5 mm
T4 Twin Scroll 1.10 A/R
4" discharge
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=161024&d=1353449437"]http://www.mkivsupra.net/vbb/attachment.php?attachmentid=161024&d=1353449437
Thanks Marc but i already ordered the 1.10 A/R, you are member of mkiv.de ?
You took my advice then ;)
Yes Paul, big thanks =)
