trinitom Posted November 5, 2012 Share Posted November 5, 2012 Hi people I have installed the new clutch pilot and release bearing to my na tt a few months ago. The release bearing its starting to squeak, I have checked the pedal clearance and is set to a maximum travel. The push rod it's completely lose, so I presume this may be a bad bearing design. Does anyone have the same problem? I was thinking in fabricating a small plate to fit under the slave cylinder to get extra clearance between the rod and fork. What do you guys think? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 5, 2012 Share Posted November 5, 2012 Remember me? Quote Link to comment Share on other sites More sharing options...
listy Posted November 5, 2012 Share Posted November 5, 2012 I have a stage 4 competition clutch in my NA-TT and have had no problems. Been in there around 10 months ish. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 6, 2012 Author Share Posted November 6, 2012 Remember me? I think I remember, didn't you had problems with the clutch even after replacement? The clutch works fine, the only problem it's the bearing noise. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 6, 2012 Share Posted November 6, 2012 I'm just being a jackass. Yer I had a totally different issues/s with mine when the material melted. I never had bearing problem, although my clutches weren't on long enough to get bearing problems lol. Although if i did the light wheel rattle most probably would have cancelled the noise out.. Quote Link to comment Share on other sites More sharing options...
