am disappointed with my new tt auto
Guest fripon
  • Replies 139
Posted Images
G morning guys,earlier on my way to work.I floored the throttle car kick down,but just not moving.rev ain't climbing.look like I got no turbo.
Best thing you could do is take it too a garage any decent garage should be able to re plumb the turbos and clear the vsv's or if your any good with the spanners do it yourself its easy enough to do
Have you opened the bonnet to make sure you have a tt motor
in there ?
It wouldn't surprise me to hear if he'd pulled the tt lump out
and dropped an na in its place, or just flogged you an na but told
you it was a tt
Pics on the first post Dunk it is a TT.
my car goes like fek son :cool: check your vacuum lines around the vsvs etc for splits, check the intercooler for leaks, it should hit 4k and literally takeoff. dont know what that bleed valve is all about but i dont think its noramlly something you'd put on TT supra, all you need is, fcd, colder plugs, restrictor ring and a decat and a good exhaust and it should boost to 1bar-1.2 bar depending on what RR you have fitted. make sure your intercooler is in awesome nic or upgrade
Superchip is an advance on the timing on most cars. It's an inline box on the wiring, and pretty obvious. It's a fag packet sized design. It will be between the ECU and the engine, probably where described under the passenger side carpet. Pull the box. It's probably causing a little bit of knock and knock sensors are pulling timing. These boxes are BAD news - worthless junk. Remove and reconnect wiring. Do at least this first before blaming mechanical VSV etc - return to stock.
Superchip on a MKIV was an expensive boost cut limiter, much better tried and tested units available.
ok gents.i have removed that bleed valve and put all the hoses back as it should.haven't test the car yet as it should.:rolleyes:tomorrow i will try to remove the superchip.
here the picture how i have put the hose back.
are these suppose to have some hose connected to it?
am trying to put the car back to standard first.
[ATTACH=CONFIG]160287[/ATTACH]
[ATTACH=CONFIG]160288[/ATTACH]
Yes they are, i will try find a pic of how they should be
