am disappointed with my new tt auto
Guest fripon
As already said, sounds like one of the valves are not working correctly and not letting the second turbo work properly.
I would avoid driving hard as you may do some damage. Does it feel like its surging a bit after 4000rpm? What does to boost to?
yes she does surge a little after 4000 rpm
  • Replies 139
Posted Images
Did you spot this car on Gumtree by any chance, and was it an Asian chap who was selling it, last 4 digits of his number were : 5143?
not on gumtree,he's Asian, that the number certainly.please don't tell me it's a lemon.:(
Edited by fripon (see edit history)
I'd read up on true twin conversion TTC etc and try that out if you are confident with playing around with the vacuum pipes, there is a massive sticky thread all on the sequential turbo system.
If you are desperate pm Ian C with the promise of a half marathon donation and he may be able to give you some pointers.
If horny devil sold it you has it actually got any turbo's ?
:D dnk lol
well ive just had the back end out pass Burton 5.0 hotel :D - I guess Im boosting fine :innocent: roads are a bit greasy tonight for boost
To the OP see if a local member will take a look for you before booking her in :)
Even a stick TT should be rapid up the whole rev range, if anything you should feel a stronger pull when the second turbo kicks in. Check out some video's on YouTube to get a rough idea.
In future when you test drive a car, demand a road to test the car properly. If the owner isn't happy with you giving it some welly then get them to drive it. I always ask if some different roads can b driven on, so bumpy roads, small roads, roundabouts & dual carriageways.
It's a bit of bad luck if you've been sold a TT that needs some work done to it.
I just hope that whoever sold it to you may have known the 2nd turbo was dodgy, and disabled it by pulling off a vacuum pipe.
I hope you get it sorted, but even a stock TT auto is a lovely motor, and would leave your GT4 well behind on full boost.
Superchip is an advance on the timing on most cars. It's an inline box on the wiring, and pretty obvious. It's a fag packet sized design. It will be between the ECU and the engine, probably where described under the passenger side carpet. Pull the box. It's probably causing a little bit of knock and knock sensors are pulling timing. These boxes are BAD news - worthless junk. Remove and reconnect wiring. Do at least this first before blaming mechanical VSV etc - return to stock.
