Chris Wilson Posted November 7, 2012 Share Posted November 7, 2012 Had a conversation with a mate at work about this issue (he knows quite a lot about engines etc) and he said there is a possibility that the heater control valve might not be opening correctly which might explain why there is no heat either side of the matrix. Does this sound like a possibility? Yes, I have seen this when water flow valves are not opening. I am pretty sure the MKIV heater uses a water flow valve, from memory. Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 7, 2012 Share Posted November 7, 2012 (edited) Yep it does and theres a diagram in the AC PDF page AC-24AC.pdf Edited November 7, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Slicknick Posted November 7, 2012 Share Posted November 7, 2012 Can you hear the motor working behind the dash when you turn the knob? I have heard of these breaking or the motor arm becoming detached. Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 7, 2012 Share Posted November 7, 2012 This thread could be of use to you http://www.mkivsupra.net/vbb/showthread.php?49871-Heater-Maximum-Output-Temperature-Too-Low/page2 Quote Link to comment Share on other sites More sharing options...
slugger1 Posted November 7, 2012 Author Share Posted November 7, 2012 Cheers for the replies. Another thing to check Quote Link to comment Share on other sites More sharing options...
slugger1 Posted November 7, 2012 Author Share Posted November 7, 2012 Can you hear the motor working behind the dash when you turn the knob? I have heard of these breaking or the motor arm becoming detached. That was one of the first things I checked. Appears to be attached ok and moving when you adjust from cold to warm temp. Quote Link to comment Share on other sites More sharing options...
slugger1 Posted November 7, 2012 Author Share Posted November 7, 2012 This thread could be of use to you http://www.mkivsupra.net/vbb/showthread.php?49871-Heater-Maximum-Output-Temperature-Too-Low/page2 I'm pretty sure mine is connected ok but will check it again just to eliminate it from the list! Quote Link to comment Share on other sites More sharing options...
slugger1 Posted November 10, 2012 Author Share Posted November 10, 2012 Sorted my heater today . Turned out it was the matrix in the end. Put the hose through it and cleared out a load of gunk. I now have heat woohoo! Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 10, 2012 Share Posted November 10, 2012 Sorted my heater today . Turned out it was the matrix in the end. Put the hose through it and cleared out a load of gunk. I now have heat woohoo! Quote Link to comment Share on other sites More sharing options...
