Kaan W Posted June 12, 2013 Share Posted June 12, 2013 Very good bit of kit it is too! As Lee says, a must if you have extra aftermarket electronics like fans, toucans, audio etc. Them Toucans use lethal amounts of power Nice, people might as well upgrade to one of these than a standard one for that price. Nice work Lee Link to comment Share on other sites More sharing options...
Brazil Posted June 12, 2013 Share Posted June 12, 2013 What is the tested result of not using a bigger amp. alternator when running 'twin fans, ice and toucan'? Link to comment Share on other sites More sharing options...
Lee P Posted June 12, 2013 Author Share Posted June 12, 2013 What is the tested result of not using a bigger amp. alternator when running 'twin fans, ice and toucan'? The problem you have is the voltage will drop very low and this effects fueling, idle and spark on boost. Also most standard alternators are 15 years old now so are getting tired. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted June 12, 2013 Share Posted June 12, 2013 What is the tested result of not using a bigger amp. alternator when running 'twin fans, ice and toucan'? With mine it just about held out while the battery was fully charged. As soon as it went flat (Audi left the lights on while doing the geo setup!) the alt. didn't have enough legs to charge it again properly, and the voltage was always really low to the point I was driving around with no radio and the toucan unplugged etc. SRD alt. solved this though - no problems since! Link to comment Share on other sites More sharing options...
Brazil Posted June 12, 2013 Share Posted June 12, 2013 The problem you have is the voltage will drop very low and this effects fueling, idle and spark on boost. Also most standard alternators are 15 years old now so are getting tired. How many hours labor does it take to change out the alternator with engine in? ''I have electric fans so there's more space to get to it now btw'. Link to comment Share on other sites More sharing options...
Brazil Posted June 12, 2013 Share Posted June 12, 2013 The problem you have is the voltage will drop very low and this effects fueling, idle and spark on boost. Also most standard alternators are 15 years old now so are getting tired. With mine it just about held out while the battery was fully charged. As soon as it went flat (Audi left the lights on while doing the geo setup!) the alt. didn't have enough legs to charge it again properly, and the voltage was always really low to the point I was driving around with no radio and the toucan unplugged etc. SRD alt. solved this though - no problems since! Lee, you have PM will be taking one please. Link to comment Share on other sites More sharing options...
Lee P Posted June 12, 2013 Author Share Posted June 12, 2013 Its an easy job with electric fans, this is a direct replacement so it plugs straight in Link to comment Share on other sites More sharing options...
Kaan W Posted June 12, 2013 Share Posted June 12, 2013 Its an easy job with electric fans, this is a direct replacement so it plugs straight in I'll be after one of these for my new engine at some point. Link to comment Share on other sites More sharing options...
Littler Posted June 12, 2013 Share Posted June 12, 2013 I might be being a bit special but what are the black and red things on the chassis leg? Lol Link to comment Share on other sites More sharing options...
Kaan W Posted June 12, 2013 Share Posted June 12, 2013 Horns Link to comment Share on other sites More sharing options...
Tsia Posted June 12, 2013 Share Posted June 12, 2013 Damnit, I was going to tell him they were electric turbos! Link to comment Share on other sites More sharing options...
Lee P Posted June 12, 2013 Author Share Posted June 12, 2013 Damnit, I was going to tell him they were electric turbos! Link to comment Share on other sites More sharing options...
Littler Posted June 12, 2013 Share Posted June 12, 2013 damnit, i was going to tell him they were electric turbos! Link to comment Share on other sites More sharing options...
Parry_10 Posted June 12, 2013 Share Posted June 12, 2013 Wow awsome work Lee:thumbs: Should do a group buy on the alternators ill be needing one for mine. Link to comment Share on other sites More sharing options...
Bailey. Posted June 12, 2013 Share Posted June 12, 2013 Crazy attention to detail there, looking forward to seeing it all done and dusted! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 12, 2013 Share Posted June 12, 2013 (edited) They are £249 and include a billet pulley. Is it an under drive pulley, if so do you need to run a longer belt to compensate on behalf of the tensioner position? Also is it a stock unit rewound, asking as the PHR one's need that extension bracket obv and this looks like it just goes on in the standard place. Gonna run Kenlowe's on mine so will probs need one! Edited June 12, 2013 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
Lee P Posted June 12, 2013 Author Share Posted June 12, 2013 Is it an under drive pulley, if so do you need to run a longer belt to compensate on behalf of the tensioner position? Also is it a stock unit rewound, asking as the PHR one's need that extension bracket obv and this looks like it just goes on in the standard place. Gonna run Kenlowe's on mine so will probs need one! Its a stock size pulley, original alternator modified so fitment is direct. Can be supplied with a smaller pulley for a boost in amperage but then you need a different size belt Link to comment Share on other sites More sharing options...
thetrashcanman Posted June 13, 2013 Share Posted June 13, 2013 Damnit, I was going to tell him they were electric turbos! They are £249 and include a billet pulley. Shall be after one of these when I get a single, I know all the stuff you sell and all the work you do is top quality Lee, and nice work on Jay's car so far and Tsia Link to comment Share on other sites More sharing options...
Hartmann Posted June 17, 2013 Share Posted June 17, 2013 pure awesomeness work !! what a car it is going to be ! may i ask how big the return line is in the fuel system ? Link to comment Share on other sites More sharing options...
Lee P Posted June 17, 2013 Author Share Posted June 17, 2013 pure awesomeness work !! what a car it is going to be ! may i ask how big the return line is in the fuel system ? Return line is -6 Link to comment Share on other sites More sharing options...
Hartmann Posted June 17, 2013 Share Posted June 17, 2013 thanks Lee Link to comment Share on other sites More sharing options...
T2 MSW Posted June 17, 2013 Share Posted June 17, 2013 May I ask where you have got the intake feed pipe from the FMIC from? I need one exactly like that for mine? Link to comment Share on other sites More sharing options...
Lee P Posted June 17, 2013 Author Share Posted June 17, 2013 May I ask where you have got the intake feed pipe from the FMIC from? I need one exactly like that for mine? We made the pipe work up Link to comment Share on other sites More sharing options...
hodge Posted June 17, 2013 Share Posted June 17, 2013 Can we have some more pics please lee. Link to comment Share on other sites More sharing options...
Lee P Posted June 17, 2013 Author Share Posted June 17, 2013 Can we have some more pics please lee. Haha... Will do soon Link to comment Share on other sites More sharing options...
