Black_Supra Posted November 5, 2012 Share Posted November 5, 2012 Hey guys, my Single Build began, going for a GW Turbokit with a BW S372 Turbo and some nice 1200 ccm Injectors & Built Head with 272 Cams (Just some Facts). Of course i want to build my block, it is now completly teared down and i am searching for the right Piston & Rod Setup, there is such a big market with many brands, whats your expirience ? HP Target >800 HP Pistons: JE; CP; MAHLE; WISECO Rods: EAGLE, MANLEY, PAUTER The most combos are around 1200/1300 $ in the USA, maybe any traders here in UK ? PM me thanks in advance Fabian Quote Link to comment Share on other sites More sharing options...
Alex Posted November 5, 2012 Share Posted November 5, 2012 I'd go for; JUN (made by Cosworth) or MAHLE pistons Carillo H-Beam rods. Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted November 5, 2012 Author Share Posted November 5, 2012 I'd go for; JUN (made by Cosworth) or MAHLE pistons Carillo H-Beam rods. Thanks mate! But i think i don`t need a 1XXX Setup, maximal for 800-1000 HP, i think i can get cheaper internals than JUN & Carillo, don`t want to spend my money in S*** but i don`t wanna buy the cheapest stuff. I read about many people in the USA driving over 1000 HP on Eagle Rods =) Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted November 5, 2012 Share Posted November 5, 2012 I have Manley H-Beam rods and Mahle pistons in mine. I'm aiming for similar power and these seemed like a good setup. Not run the engine yet but should be back on the road next summer. Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted November 5, 2012 Author Share Posted November 5, 2012 I have Manley H-Beam rods and Mahle pistons in mine. I'm aiming for similar power and these seemed like a good setup. Not run the engine yet but should be back on the road next summer. Sounds like a good Setup to me, where you bought the stuff ? thanks Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted November 5, 2012 Share Posted November 5, 2012 Bought this all through Paul Whiffin. I have the 280 cams with a sage 2 head with dual springs and titanium retainers. I'm going to run this on a Batmowheel S366 and should clear 800 and still retain a good power band through the rev range. Paul mentioned a race jacket which increases spool times which I might try too. Might want to consider the same? Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted November 5, 2012 Author Share Posted November 5, 2012 Bought this all through Paul Whiffin. I have the 280 cams with a sage 2 head with dual springs and titanium retainers. I'm going to run this on a Batmowheel S366 and should clear 800 and still retain a good power band through the rev range. Paul mentioned a race jacket which increases spool times which I might try too. Might want to consider the same? Visited your Build Thread, i think we got nearly the same plans Will open a Build-Thread Today evening =) Thanks in advance Fabian Quote Link to comment Share on other sites More sharing options...
Nic Posted November 5, 2012 Share Posted November 5, 2012 I'd go for; JUN (made by Cosworth) or MAHLE pistons Carillo H-Beam rods. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 5, 2012 Share Posted November 5, 2012 See, now I don't get tuning like this. If you're going to build an engine, why wouldn't you want the best in it? I'm not talking F1 quality, just best off the shelf. I prefer to use items that have been proven. Carillo's will out last 99% of the others. JUN pistons will be high grade alloy and will not warp under extreme heat/load, I remember CW getting a CP piston and was horrified at how out of shape it was from the factory... Decent parts aren't just about power, they are about longevity they may be the difference between 1 expensive rebuild and down-time vs multiple labour intensive rebuilds with cheaper parts. Quote Link to comment Share on other sites More sharing options...
Krister Posted November 8, 2012 Share Posted November 8, 2012 (edited) There's no point in over building it just because there is higher end parts available. I've had Eagle / CP rod combo for three years and last year was at over 1100hp. My engine was built for 900hp in mind, but I got a little carried away... For the regular blokes 700-900hp, Eagle and JE/CP etc combo will be more than enough. I even ran with the stock engine for two years at 800hp. Edited November 8, 2012 by Krister (see edit history) Quote Link to comment Share on other sites More sharing options...
