Help - my sidelights are stuck on...
fri3ndly
I walked out to my Supra this evening to find that the sidelights were on. I got in and found that they were on despite the lights being switched off which was strange. Anyway I proceeded to go for a drive to get some grub and when I arrived at the takeaway I switched them off and they were propery off, but then when I returned to the car they were on again.
I'm worried this can't be good for my battery...the car is sitting on my drive with it's front and rear lights on and there's nothing I can do :(
Any advice? Did a search but seems nobody has a car playing tricks on them like this!
Guest Rsand85
sounds a bit like a bas earth somewhare dude
hard to say, as everything also goes through the main light swich on the stalk. This uses a switch earth setup - as mentioned already, could be iffy earth, but in the switch
Good info should it ever happen to other members. I just thought that relays were prone to sticking, especially in cold weather. I am judging this by some of the stuff that goes on at work although it may not be relevant when it comes to cars.
H.
H.
Fair one, but as I gather, this "intergration relay" is electroinc relay - no mechanical moving parts.. logic etc...
Cool. I have been on this forum 6 years and still know bugger all about what goes on behind the dash or under the bonnet for that matter...lol.!!
You know don't you? Every time I came round you just leave me to it whilst you play COD instead of learning!
