Hartmann Posted October 31, 2012 Share Posted October 31, 2012 hi guys . what are the thourghts about mounting the oil and PAS-cooler between the IC and the radiator ? some say nono others never had an issue ? going to run about 800bhp. 4-5inch ic and a aftermarket alloy radiator ,.. i have an 16 (or 19) row Whifbitz oil-cooler kit for the motor. is that enough ? what are the concernes ? high water temp, high oil temp or both ? Quote Link to comment Share on other sites More sharing options...
tony tt Posted October 31, 2012 Share Posted October 31, 2012 Could it be mounted in the area where the smic would be located at the side of the fmic? Quote Link to comment Share on other sites More sharing options...
hodge Posted October 31, 2012 Share Posted October 31, 2012 hi guys . what are the thourghts about mounting the oil and PAS-cooler between the IC and the radiator ? some say nono others never had an issue ? going to run about 800bhp. 4-5inch ic and a aftermarket alloy radiator ,.. i have an 16 (or 19) row Whifbitz oil-cooler kit for the motor. is that enough ? what are the concernes ? high water temp, high oil temp or both ? Your cooling won't be anywhere near as good mounting it there. I'd personally mount the oil cooler in a side duct. Unless your going to track your car, I wouldn't bother with a PAS cooler, it's just not needed. Quote Link to comment Share on other sites More sharing options...
Hartmann Posted October 31, 2012 Author Share Posted October 31, 2012 Your cooling won't be anywhere near as good mounting it there. I'd personally mount the oil cooler in a side duct. Unless your going to track your car, I wouldn't bother with a PAS cooler, it's just not needed. okay .. would do a bit of track-day but no racing the car on the track like i`v stole it .. about the side duct . i cant se how i could get the room for it with the IC pipe in the way .. but would be happy if some on could upload some pictures of there set-up Quote Link to comment Share on other sites More sharing options...
Hartmann Posted November 1, 2012 Author Share Posted November 1, 2012 hey guys .. did a mark-up of the new spot as doctor Hodge ordered think that is a way better place to mount it Quote Link to comment Share on other sites More sharing options...
basaez Posted November 1, 2012 Share Posted November 1, 2012 I think if you turn you oil cooler its going to better connectors up Quote Link to comment Share on other sites More sharing options...
Hartmann Posted November 1, 2012 Author Share Posted November 1, 2012 was under the impression that it doesen´t matter that much ? Quote Link to comment Share on other sites More sharing options...
Hartmann Posted November 1, 2012 Author Share Posted November 1, 2012 yes . along as you get the air out of the system. it can be mounted opsite down so no problems according to MOCAL Quote Link to comment Share on other sites More sharing options...
