MOT: HID revert back to OEM
Jellybean
Can you not just plug in a set of standard bulbs or is the HID kit hard wired into the loom?
It is the bellof kit so it looks as though it is plug and play but I am not 100% as I dont have another Supra for comparison
Hopefully somebody will know if it is just as simple as plug in a set of standard bulbs
Tonytt and Ross C had their MOTs recently and they both passed and run HIDs iirc
Are they UK spec Supra's , I know they have at least the headlamp washer as standard
Just doing my research incase I fail, I will throw her in as is but just want to be ready
From what I am reading it is not getting inforced
There should be a Brown Plug on the end of the wiring loom near the headlight on either side, this is usually where the standard bulb would fit, what you will have it this brown plug and the ballast attached, then from the ballast you will have the HID bulb lead with the bulb at the end going into your headlight. All you need to do is remove the Ballast from the Brown OEM connector and then attach a standard bulf to the brown plug.
Hope this makes sense.
http://www.mkivsupra.net/vbb/showthread.php?277991-Group-buy-HID-install-guide bit like this but in reversal
Edited by SPG (see edit history)
Thanks , thats great; excatly how mine is setup
As I am in Ireland we have the NCT , HID lamp reasons for failure (not too sure how strict they are)
16 Automatic headlamp levelling device not operating or manual headlamp levelling device cannot be operated from driver’s seat.
17 Mandatory headlamp cleaning device not present.
18 Mandatory headlamp cleaning device not operating.
If the car isn't fitted with headlight levellers from drivers seat how can it be a failure? Headlight cleaning device? So if your car isn't fitted with these as standard it a failure? Am I missing something. The nct is a rip off you don't even get the weeks grace then free retest when you go back you need to pay for the full test again. Rip off republic for sure. Move to the uk bud its far easier. :)
- - - Updated - - -
Mine passed with hIds too aslong as the a at the correct height and working they should be fine
In the uk yes but the NCT in Ireland is different.
UK MOT it's not a failure or an advisory to have HIDs with no washers or levelling, but looks like the Ireland test is a fail to not have washers on the car.
17 Mandatory headlamp cleaning device not present.if
If its an import supra it won't have headlight cleaners or self levelling adjusters from the drivers seat.
If its not fitted as standard it needs to be working for the nct but failing it for not having it is a joke. Does that mean all the shitbox corollas over there all fail on this as well? It's only mandatory if there factory fitted your nct tester is a twat.
Basically, what that means is if the above is fitted, it should be in working order. If it isn't, as in most cases for JSpecs, then it's not a problem, but if you have a UK Supra, then the headlamp washer/wipers have to work, etc.
Well I haven't looked up the NCT inspection manual or anything but from Jellys post it looks like that's the rule.
Not unless the rules have changed I live there for 6 years in Kerry and headlight washers wasn't an issue. As said by Andrew though if its a uk spec supra then these would be relevant failures.
This got covered earlier in the year.
If your car is fitted with washers and alignment as standard (uk spec) it has to be in working order to pass with HIDs.
If your car was not fitted with washers and alignment as standard (jspec) then HIDs will pass as long as they have the correct level and beam pattern.
They may have changed as most MOT type rules changed this year.
Was it covered for the Irish test though, or just the MOT?
For the MOT you can have HIDs and don't need any washers or auto-levelling, if you have washers they now have to work.
For the Irish NCT test it states as one of the reasons for failure (so called RfRs on the MOT over here) that for HIDs: "Mandatory headlamp cleaning device not present.". So unless the testers don't read the manual, or don't care, or for some other reason don't fail the car for it then it is a failure to not have a washer system fitted.
I am not too sure if it is the case over here, sure I guess I will find out on the 12th
Will keep the thread updated
http://www.ncts.ie/pdf/NCT%20Manual%...May%202012.pdf
Page 47
4. Where HID (High Intensity Discharge) bulbs are fitted switch on the headlights and check that cleaning devices such as headlamp 4. wipers or high pressure water jets are present and work. Check where possible that the headlamp levelling device is working.
Notes:
4. HID headlamps must be installed as a complete type-approved system. The system will include automatic cleaning. HID headlamps can be recognised by:
a) the light having a bluish tinge,
b) the light taking a few seconds to reach full intensity,
c) the headlamp having an igniter module/inverter behind the headlamp,
d) the headlamp having ”DC” (for HID dipped beam), “DR” (for HID main beam), or “DCR” (if both are HID) marked on the lens. This marking should be visible from the exterior of the vehicle but in some cases the markings may be hidden under the bonnet and this may need opening to obtain a clear view.
