Syvecs Wiring Questions
Kev.O
Guys,
I'm in the process on helping someone re-wire a Supra which will be road legal but built for the strip.
I have a couple of questions that I would really appreciate some input on please.
Does the Syvecs need to see an input from the brake sensor or reverse sensor?
Where do I wire the Dash 2 Can bus into (I'll take a picture of the ECU loom)?
Thanks in Advance.
As I'm planning on using the Can bus, am I right in saying that the Dash 2 doesn't need to have the speed sensors/speedo hard wired into the back of the Dash 2 as it will receive this information via the serial lead (Can bus)? It's just the lights/indicators/fuel/power that I need to hard wire?
Correct :)
I will dig out the drawings I have. Send us your email address Kev :)
Am I right in saying the auxiliary outputs go to ground when activated? I'm looking at wiring the twin electric fans soon and wondered if it was a switched positive or switched negative.
They go to ground when activated.
