IamLukeMachin Posted October 28, 2012 Share Posted October 28, 2012 The time is comingup when the Supra needs an oil change. So question is what do you use? or what would you say the best was? 3L N/A engine, and I guess a genuie toyota oil filter from Paul is best to use? Thanks in advanced. Luke Quote Link to comment Share on other sites More sharing options...
Josh42 Posted October 28, 2012 Share Posted October 28, 2012 There's a thread in the FAQ's about fluids:) Quote Link to comment Share on other sites More sharing options...
safcdixon Posted October 28, 2012 Share Posted October 28, 2012 http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted October 28, 2012 Share Posted October 28, 2012 If you are still unsure you could always contact Opie Oils, they are a trader in the forum and are very knowledgeable. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 28, 2012 Share Posted October 28, 2012 A basic 10W 40 semi synthetic, and a blueprint pattern filter will be fine, even the most basic modern oils will far exceed the specs of the original Toyota specified oil. Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 28, 2012 Share Posted October 28, 2012 I use Silkolene pro 10W40. Quote Link to comment Share on other sites More sharing options...
