Cars back at garage whifbitz for a bit of tweaking
tooquicktostop
Had an annoying oil leak for some time now so decided to replace oil pump and main seal as well as have a bit of strength added to the bottom end in the way of rod bolts, main bolts and bearing shells (if needed once checked) of course it also had the new TRD engine mounts and Volks wheels fitted as planned
Look forward to getting it back early next week
Where was the oil leak coming from bud?
The work being done, is that an engine out?
It was my fault, I did not take the opportunity to replace the oil pump last time the engine was out so we think it was this that was the fault, replaced the front crank seal and gearbox rear seal as well
Engine in, sub frame off
