Chris Wilson Posted October 26, 2012 Share Posted October 26, 2012 You needa good garage to put the oscilloscope on the control pins of IACV and see if the ecu is sending a suitable control signal to them. Check it moves fully when removed and ignition is turned off then on. Clean it. Go from there. Without proper diagnostic gear you are wasting your time, you need to be able to see the control signals, or lack of. Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted October 26, 2012 Author Share Posted October 26, 2012 Ok changing the spark plugs did nothing I am still having the same issues with starting. Basically car runs no different with the new plugs. It will crank and fire up but right away on a cold engine... but the the RPM will drop and it'll die right after that. I have to attempt starting it usually around 3 times before it holds an idle. It will bounce back and forth between 600-700 and car will roughly shake. Once it warms up for a couple minutes it seems to run perfectly fine. What coud be the next thing I should have checked? It has brand new plugs and clean idle control valve. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2012 Share Posted October 26, 2012 As I said, you need to look to see if the idle control valve is getting a proper control signal from the ECU. I strikes me it's not "parking" properly. Quote Link to comment Share on other sites More sharing options...
tony tt Posted October 27, 2012 Share Posted October 27, 2012 (edited) I would have thought they were increments of 200 if 1 = 1000rpm. My TT auto idles exactly the same as the pic cleaned icv and changed the o2 sensor and its still the same idles at 350 ish. Right I'm a div increment reading is about 650 then. Edited October 27, 2012 by tony tt (see edit history) Quote Link to comment Share on other sites More sharing options...
tony tt Posted October 27, 2012 Share Posted October 27, 2012 0 First mark is 500 Every mark after that increases by 100 until 1kRPM I just noticed that I really must pay more attention. Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted October 27, 2012 Author Share Posted October 27, 2012 As I said, you need to look to see if the idle control valve is getting a proper control signal from the ECU. I strikes me it's not "parking" properly. My mechanic has IACV almost new condition, we will throw it in and the next day start the car up and see if that did it.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 27, 2012 Share Posted October 27, 2012 Is throwing bits at it the new diagnosis? Quote Link to comment Share on other sites More sharing options...
bambisdad Posted October 27, 2012 Share Posted October 27, 2012 Looks like 650 to me too. I think what is throwing you is that there are no markings for the first 500 rpm. Quote Link to comment Share on other sites More sharing options...
Wez Posted October 27, 2012 Share Posted October 27, 2012 is throwing bits at it the new diagnosis? Quote Link to comment Share on other sites More sharing options...
johnny g Posted October 27, 2012 Share Posted October 27, 2012 Is throwing bits at it the new diagnosis? Quote Link to comment Share on other sites More sharing options...
