Guest Bobby Dazzler Posted October 21, 2012 Share Posted October 21, 2012 Hi Chaps, Can someone please give me a little advice. I own a 95 N/A and want to fit an Oem bonnet scoop from a turbo. Just need to know if the large underbonnet metal airguide plate will fit with the N/A engine as it looks as if the inlet manifold or throttle housing might be in the way. If so has anyone made thier own guide plate. I have everything else apart from guide plate and don't want to buy one if it won't fit. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Share Posted October 21, 2012 Bonnet scoop isn't from turbo models mate, it's a uk spec thing. I'm not sure if it would fit or not. Can't remember if NAs were sold in uk spec. Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 21, 2012 Share Posted October 21, 2012 Bonnet scoop isn't from turbo models mate, it's a uk spec thing. I'm not sure if it would fit or not. Can't remember if NAs were sold in uk spec. Uk's were turbo only. Quote Link to comment Share on other sites More sharing options...
Paul Posted October 21, 2012 Share Posted October 21, 2012 Bonnet scoop isn't from turbo models mate, it's a uk spec thing Mine must be rarer still, it's UK, Turbo and Bonnet scoop fitted As said UK models are only turbo versions and they have the scoop. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Share Posted October 21, 2012 My point was jspec twins never had a scoop, but the uk specs did. So it's a uk spec thing, not a turbo thing. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2012 Share Posted October 21, 2012 I'd buy the under shield first and check for clearance before committing to the (expensive) scoop. Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 21, 2012 Share Posted October 21, 2012 Just fit the scoop, but don't bother adding the hole & air guide underneath. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Share Posted October 21, 2012 Or see if someone near you has a uk spec bonnet that wouldn't mind you test fitting it. Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 21, 2012 Share Posted October 21, 2012 Just fit the scoop, but don't bother adding the hole & air guide underneath. The reason it was fitted was for adding cooling during high speed cruising so unless you intend to do long journeys at 100+ mph the rest of the system really isn't needed. Quote Link to comment Share on other sites More sharing options...
Guest Bobby Dazzler Posted October 21, 2012 Share Posted October 21, 2012 Thanx for the quick replies chaps. I am aware that uk spec did not produce the N/A. Just need to know if that big metal air guide plate won't interfere with the inlet over the rocker. I already have everything bar the airguide plate. Just fitting the scoop for looks and not necessarilly wanting to cool down 5 & 6 cylinders. Sorry SteveR, Won't be taking your advice and risk it flying off at speed. I like to do things right. Quote Link to comment Share on other sites More sharing options...
Guest Bobby Dazzler Posted October 21, 2012 Share Posted October 21, 2012 Thanx for that info Listy, Always wondered why i saw alot of tt's without the bonnet scoops. I just love the scoop look as it finishes it off and especially with the active spoiler aswell. I wanted a tt but my budget wouldn't allow, I will get one before i die though. Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 21, 2012 Share Posted October 21, 2012 Sorry SteveR, Won't be taking your advice and risk it flying off at speed. I like to do things right. Donkey, the guide doesn't hold it on. "Doing it right".... pfft. Criticise when you know what you're on about. I have the scoop but no air guide. It's fine at 175mph. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 21, 2012 Share Posted October 21, 2012 (edited) Mine hasn't got the air guide underneath and hasn't flown off either for quite a few years. The guide only directs air to the air inlet duct (snorkel) which bolts to the side of the engine on a UK car (red arrow) Edited October 21, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 21, 2012 Share Posted October 21, 2012 And Dnk drives faster than me, so it's fine at 180mph too then. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 21, 2012 Share Posted October 21, 2012 And Dnk drives faster than me, so it's fine at 180mph too then. not guilty your honour Quote Link to comment Share on other sites More sharing options...
Marcus GTE Posted October 21, 2012 Share Posted October 21, 2012 The reason it was fitted was for adding cooling during high speed cruising so unless you intend to do long journeys at 100+ mph the rest of the system really isn't needed. Think I remember reading that it was required due to extra heat generated by the exhaust gas recirculation system the UK spec uses in order to meet the emissions regulations at the time and that the scoop also adds 1bpu (according to Toyota) I like how it has a purpose and isn't just cosmetic Quote Link to comment Share on other sites More sharing options...
Guest Bobby Dazzler Posted October 21, 2012 Share Posted October 21, 2012 I sincerely apologise steve for my ignorance. It's just that i was picturing trapped air in the scoop at high speed and thought it would cause some drag/noise or worse make the scoop come loose. Do you forgive me? no ones perfect and i am not. At least i am man enough to apologise and admit that i have embarrassed myself. I'm not a bad chap really. hope my comment hasn't offended as i love the club. guess i will be just bolting it on then:rolleyes: Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 22, 2012 Share Posted October 22, 2012 Are you cutting the bonnet the same as the UK spec to let the air going into the scoop actually go into the engine bay ? Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted October 22, 2012 Share Posted October 22, 2012 the extra cooling wont make a difference on an n/a Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 22, 2012 Share Posted October 22, 2012 the extra cooling wont make a difference on an n/a That's not why i asked my question if your post is in reply to mine above ! Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted October 22, 2012 Share Posted October 22, 2012 That's not why i asked my question if your post is in reply to mine above ! wasnt replying to you dnk, just a generic n/a slating post Quote Link to comment Share on other sites More sharing options...
listy Posted October 22, 2012 Share Posted October 22, 2012 wasnt replying to you dnk, just a generic n/a slating post Quote Link to comment Share on other sites More sharing options...
Guest Bobby Dazzler Posted October 22, 2012 Share Posted October 22, 2012 Hi Dnk, Firstly i am just fitting it for looks and i downloaded a walk through from mk4.com which is easy to follow. I am going to make the hole because the 2 brackets and plastic plate which holds the other 2 bolts sits lower than the bonnet so this is why i have to cut through, the only reason i wanted advice for an air guide is simply because i certainly do not want water near the engine. I may make something to attach so that any drafted water will pass. Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 22, 2012 Share Posted October 22, 2012 I sincerely apologise steve for my ignorance. It's just that i was picturing trapped air in the scoop at high speed and thought it would cause some drag/noise or worse make the scoop come loose. Do you forgive me? no ones perfect and i am not. At least i am man enough to apologise and admit that i have embarrassed myself. I'm not a bad chap really. hope my comment hasn't offended as i love the club. guess i will be just bolting it on then:rolleyes: No worries, sorry if I was OTT and jumped down your throat. If it's just for the look, fix it to the bonnet and don't bother with any holes. Honestly, it'll be fine. Quote Link to comment Share on other sites More sharing options...
shifted Posted October 23, 2012 Share Posted October 23, 2012 I'm looking to fit one of these myself to a JDM RZ in the near future but I never realised there was a little snorkel in the bay - probably won't be using that and just fitting it to the cut and letting the cold air get into the rear of the engine (I'll be attending more and more track events as time goes on) - never thought about water getting into the engine bay through it - anyone have that problem? (Sorry to hijack a little!) Quote Link to comment Share on other sites More sharing options...
