listy Posted October 21, 2012 Share Posted October 21, 2012 With all the exhaust dramas people have been having lately, I thought I'd ask a question for the boffins. Now, we all know people tend to get 3" or 4" exhausts. The problem with 4" being a) the noise and b) the ground clearance. Now, I was wondering if, rather than having a round pipe exhaust, how an oval pipe exhaust would be. Now, I know it's all about cubic area for restrictions and allowing as much gases out though the exhaust as possible, but has anyone gone the route of a custom oval pipe exhaust, to get over the ground clearance issue? And, what kind of dimensions would the oval pipe need to be to match say, a 4" exhaust? When it comes to the back box, would it be possible to customise one so that the oval pipe went into the round pipe of the back box, as long as the cubic areas match, without then limiting the flow? As I think to have an oval back box would be a custom job? Discuss Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 21, 2012 Share Posted October 21, 2012 (edited) Oval pipe is a bitch to bend My Drager pipework is 95 mm and i don't get many problems and the car is lowered on Eibachs, its also not that loud Edited October 21, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 As it would be a custom job, would it not be ok to cut and weld it to the correct shape? I don't really know exhausts would angular bends apposed to rounded bends make a big difference? I'm thinking from first decat by the way, to allow plenty of ground clearance. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 21, 2012 Share Posted October 21, 2012 More trouble than it's worth IMO. Just buy a decent exhaust to begin with. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 The point isn't the exhaust itself, it's about gaining ground clearance and still allowing the same flow rate as a 4". I have some horrendous speed bumps in my area, and my 3" catches on half of them already. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 21, 2012 Share Posted October 21, 2012 would angular bends apposed to rounded bends make a big difference? Yes. You want it as straight as possible. Any disturbance in gas flow can cause back-pressure which will cause power-loss issues. Quote Link to comment Share on other sites More sharing options...
johnny g Posted October 21, 2012 Share Posted October 21, 2012 would angular bends apposed to rounded bends make a big difference? Yep. An exhaust (in theory) will only flow the maximum of it's narrowest point. An angular bend in 4" might knock it down to 2.5", therefore you have 2.5" (e.g. restrictor rings). Mandrel (round) bends keep a constant radius in the pipework. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 21, 2012 Share Posted October 21, 2012 The point isn't the exhaust itself, it's about gaining ground clearance and still allowing the same flow rate as a 4". I had a Whifbitz twin box system on my old single Supra and it was perfect. My car was very low. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 Yep. An exhaust (in theory) will only flow the maximum of it's narrowest point. An angular bend in 4" might knock it down to 2.5", therefore you have 2.5" (e.g. restrictor rings). Mandrel (round) bends keep a constant radius in the pipework. Ah, I see. Thought there must be a reason I haven't seen it done. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 21, 2012 Share Posted October 21, 2012 (edited) http://www.spintechmufflers.com/oval-tubing/customized-tubing/cat_137.html Edited October 21, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted October 21, 2012 Share Posted October 21, 2012 Why do you need a 4inch exhaust anyway? Not needed unless your running mega power just stick with 3-3.5inch Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 21, 2012 Share Posted October 21, 2012 4" oval with 3.5" cut out. http://imageshack.us/a/img197/6589/dscn1270q.jpg When you mess with oval you need a top fabricator, simple as that. Quote Link to comment Share on other sites More sharing options...
johnny g Posted October 21, 2012 Share Posted October 21, 2012 Why do you need a 4inch exhaust anyway? Not needed unless your running mega power just stick with 3-3.5inch This. If you're going for over 650bhp, then I think you'll need 4", under than you'll be perfectly good with 3" Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 This is all just for future plans really. Not for what I have now Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 21, 2012 Share Posted October 21, 2012 Ground clearance of an oval cannot be matched and the flow is more or less the same as a normal 4" exhaust. As I said though you need a very good fabricator as it's very easy to get it wrong. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted October 21, 2012 Share Posted October 21, 2012 This is all just for future plans really. Not for what I have now In that case I would say go 4 inch exhaust when/if you actually need to. No point doing it now especially if you current exhaust already catches. Chances are by the time you actually need the 4 inch exhaust you would have probably damaged/dented it which will restrict it anyway;) Quote Link to comment Share on other sites More sharing options...
Noz Posted October 21, 2012 Share Posted October 21, 2012 Not worth the hassle. Raise the car up. If you have to. Im changing my exhaust and I have bumps as well (like you know mate when you crashed into it when you came to visit) but I'll sort the issue if there is one rather than pay ££££££££££ to keep it 10-30mm lower. You won't want 650bhp on a car that's too low anyway. Handling will be aweful if it's too low, more power will make it harder and less enjoyable. Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 This idea wouldn't be followed up for a while yet. Not until the rest of the bits have been sourced. @Noz that pot hole was horrendous lol Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted October 21, 2012 Share Posted October 21, 2012 This idea wouldn't be followed up for a while yet. Not until the rest of the bits have been sourced. @Noz that pot hole was horrendous lol Sounds good mate look forward to the updates. Nothing wrong with asking questions and planning ahead:) Quote Link to comment Share on other sites More sharing options...
listy Posted October 21, 2012 Author Share Posted October 21, 2012 My thinking exactly mate. Probably wont happen for a couple of years yet lol but collecting parts as and when the money is there and bargains come up. I'm in no rush to go single, but trying to gather all I can bit by bit. Plan on getting a second engine at some point, so I can build it outside the car. That's last on the list though Quote Link to comment Share on other sites More sharing options...
Nic Posted October 22, 2012 Share Posted October 22, 2012 3" off the shelf exhaust, job done. Quote Link to comment Share on other sites More sharing options...
