Shock absorber question!
Supra Ems
Hey guys,
My poor Supra has just failed it's MOT on a leaky shock. I'm looking to upgrade them. Does anyone know if there is any difference between the NA and TT suspension before I fork out on a set? Mine is NA. Any recommendations? Also, Is it a job for an amateur mechanic (fitted shocks on a few other cars before) or the garage?
Thanks!
I'd go with a set of the optional Toyota/Bilstein dampers and perhaps a set of Eibach springs. Easy enough to fit if you have somewhere dry to work and have a good set of tools. You'll need to get the geometry checked/adjusted once fitted.
2 x 48510-09016 Toyota/Bilstein Damper
2 x 48530-09016 Toyota/Bilstein Damper
http://img215.imageshack.us/img215/1017/cimg00037nc.jpg
How much are they new?
Hey guys,
Thanks!
Not sure about the internals of the shocks but they are interchangeable. Spring rates are deffo different due to weight of car.
Get in touch with Chris Wilson on here. New set of German spec Bilsteins with great aftercare. :thumbs:
Forget Demon Tweeks.
Teins are without doubt, the most unforgiving, bone crunching 'suspension' out there. Also why did you log on, ask a question then not take the advice?
I had to make a decision today to order them in time to fit them before the MOT retest! I didn't see the other replies till too late, sadly. I'll have to wait and see if they loosen any dental fillings. I quite like a stiff ride anyway ;)
If they're worse than the Cuscos on my Soarer they must actually be solid. :)
My Soarer came with Teins, and I actually bought a set in years gone by. You tend to develop a 6th sense for avoiding pot holes and drain covers. Now running HSDs and Im very pleased with the ride.
