thetrashcanman Posted October 21, 2012 Share Posted October 21, 2012 Good man! Don't give up quite yet Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2012 Share Posted October 21, 2012 Has it got an FCD fitted? If so remove it and out the wiring back to stock. Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 21, 2012 Author Share Posted October 21, 2012 Has it got an FCD fitted? If so remove it and out the wiring back to stock. Nope not as far as i can see. The engine was stock as far as i know. I have a feeling its something sticking where the block sat for a while in my lock up. I will swap the whole rail out and then see what happens. Im taking my cam next week so i can post vid of it doing its thing. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2012 Share Posted October 21, 2012 If you keep trying it in such a state you WILL knacker it up, good and proper Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 21, 2012 Author Share Posted October 21, 2012 Even turning it over for 30 seconds? Or less. How will anyone test it without turning it on Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2012 Share Posted October 21, 2012 Hopefully they will be able to trace the issue WITHOUT firing it up. I definitely wouldn't try and start it again, most definitely!! Quote Link to comment Share on other sites More sharing options...
mellonman Posted October 22, 2012 Share Posted October 22, 2012 i would start be going over every single conection that you have done changing the loom and engine. checking for damage along the way. are you 100% sure its petrol coming out the exhaust,not water stuck in the exhaust from engine swop? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2012 Share Posted October 22, 2012 Start by finding and posting the injector dwell time on cranking. If you don't have the means to do this you are wasting your time (and time IS money). Then we cann see if the injectors are firing something like correctly. Also post fuel rail pressure with no vac to the regulator. Signal voltage levels from MAP, TPS and coolant temp sensors next. Absolute cheapest way to have even a clue about injector timing is some Noid lights off Ebay, but you should just get a pro to have a look at it. Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 22, 2012 Share Posted October 22, 2012 Is it possible it is water in the exhaust and it is running rich making the water smell like petrol ? Have you tried collecting some of the fluid and trying to ignite it ? (not in the garage of course ) Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 22, 2012 Share Posted October 22, 2012 Sorry if i missed it but does it actually run and tickover without missfire Quote Link to comment Share on other sites More sharing options...
Noz Posted October 22, 2012 Share Posted October 22, 2012 drop it to chris wilson for sure Quote Link to comment Share on other sites More sharing options...
Wez Posted October 22, 2012 Share Posted October 22, 2012 If its really that rich then surely bore wash would be a major issue, you should diagnose the fault without running it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2012 Share Posted October 22, 2012 Is it possible it is water in the exhaust and it is running rich making the water smell like petrol ? Have you tried collecting some of the fluid and trying to ignite it ? (not in the garage of course ) If it's as bad as it sounds I think lighting it in the garage is a very GOOD idea Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 28, 2012 Author Share Posted October 28, 2012 Well im half way to removing the rail, injecs, FPR. I will try the known good set then get it trailered somewhere. From what your all saying its shot anyway so nothing to lose. Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 28, 2012 Author Share Posted October 28, 2012 Out of wondering who is the closest person to take this to? Id love to let CW take a look but the cost of a trailer to Shropshire Quote Link to comment Share on other sites More sharing options...
mellonman Posted October 28, 2012 Share Posted October 28, 2012 probably tdi essex its just over the dartford bridge but failing that whifbitz round the m25 more Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 28, 2012 Share Posted October 28, 2012 In the grand scale of building and running these things if you had to trailer it to John 'O' Groats and back it would be chicken feed against your overall annual costs. I would take somewhere with a proven record of engine diagnostics. Whether they have even ever seen a Supra or 2JZ-GTE is irrelevant. A car is a car, a loom a loom, sensors are sensors and they all work on the same basic principles. Judge them on whether they understand these basics and have the gear to analyse and isolate an issue without parts bin swapping. My address is in my sig..... Quote Link to comment Share on other sites More sharing options...
haz182 Posted October 28, 2012 Share Posted October 28, 2012 tony gillam 34 just before the dartford crossing are a good garage too. Quote Link to comment Share on other sites More sharing options...
Nikue Posted October 28, 2012 Share Posted October 28, 2012 (edited) I read somewhere if you book an appointment for an MOT somewhere you are legally OK to drive it there even without an MOT. But if the cops stop you , you will need proof of the MOT appointment. Edited October 28, 2012 by Nikue (see edit history) Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted October 28, 2012 Share Posted October 28, 2012 I read somewhere if you book an appointment for an MOT somewhere you are legally OK to drive it there even without an MOT. But if the cops stop you , you will need proof of the MOT appointment. 100% true Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 29, 2012 Author Share Posted October 29, 2012 LMAO driving it is not a option. Starting it is by all accounts not a good idea. I think if it was to move it would probably do about 1mpg Quote Link to comment Share on other sites More sharing options...
Noz Posted November 19, 2012 Share Posted November 19, 2012 any progress? Quote Link to comment Share on other sites More sharing options...
