Kev.O Posted October 17, 2012 Share Posted October 17, 2012 Can anyone tell me what this part is please? It's located on the drivers side above the fuse board and bolted to the metal work of the car. It connects to the white 16 way connector on the passengers footwell. I have tried looking through the manuals and using the search function, but it's difficult trying to search for something you don't know the name of : Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2012 Share Posted October 17, 2012 It's a bomb! Quote Link to comment Share on other sites More sharing options...
Porky1978 Posted October 17, 2012 Share Posted October 17, 2012 Is there a part number on it? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 17, 2012 Share Posted October 17, 2012 Kickdown switch/throttle pedal stop. Should be bolted to the floor below the throttle pedal. Is your car an auto to manual conversion? Quote Link to comment Share on other sites More sharing options...
Littler Posted October 17, 2012 Share Posted October 17, 2012 As James says it looks like the kick down switch Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 17, 2012 Author Share Posted October 17, 2012 I'll have a look for a part number tonight. I'm working on a wiring loom for a friend, though I believe it might have been an auto. A kick down would made sense. I was thinking it bolted to the side fo the car as it's about 300mm from the drivers fuseboard. It's wired to the passengers connectors, a white block, on the left hand side of the group of connectors. All the other wires leading to this connector block have been removed, wich made tracking it down that little bit harder. Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 17, 2012 Share Posted October 17, 2012 Looks the same as the kickdown switch I took out of a GS300. It sits directly in the path of the throttle pedal, for obvious reasons. Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 17, 2012 Share Posted October 17, 2012 Its a kick down switch, I still have mine from my auto to manual swap. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 17, 2012 Author Share Posted October 17, 2012 Perfect, thanks chaps. I didn't think I recognised it. There is no part number on the switch that I can see. Quote Link to comment Share on other sites More sharing options...
