T2 MSW Posted October 17, 2012 Share Posted October 17, 2012 Link to comment Share on other sites More sharing options...
Josh Posted October 17, 2012 Share Posted October 17, 2012 Basic Install..... Syvecs S6GP is £1560 - Purchase from Syvecs Loom adaptor is £175 - Purchase from Syvecs Knock sensor £35 - Purchase from Syvecs Boost solenoid £40 -Purchase from Syvecs 3bar map sensor £70 - Not need for NA-T Mapping £350 -£450 depending on features - NA-T will be £350 which is all done on dyno Includes: Launch control Antitheft Mode Valet Mode Adjustable boost Adjustable maps Safety trips Onboard logging Nitrous setup Etc Extras..... Not necessary Traction control wiring and setup £75 Wideband Lambda sensor for Closed loop lambda £160 Fuel pressure sensor monitoring £60 Oil pressure sensor monitoring £85 So about £2000 plus mapping. Seems worth it to know the engine's safe, especially if Ryan maps it. If/when I go single, I'd make sure I had the money for a Syvecs. Link to comment Share on other sites More sharing options...
Wez Posted October 17, 2012 Share Posted October 17, 2012 So about £2000 plus mapping. Seems worth it to know the engine's safe, especially if Ryan maps it. If/when I go single, I'd make sure I had the money for a Syvecs. Looks more like £2160 incl mapping Link to comment Share on other sites More sharing options...
Josh Posted October 17, 2012 Share Posted October 17, 2012 Looks more like £2160 incl mapping Link to comment Share on other sites More sharing options...
Noz Posted October 17, 2012 Author Share Posted October 17, 2012 I would obviously like the best I can buy for my money, but its gone from a remap, to a new standalone, to a top premium product. Still unsure where I'll go from here. Link to comment Share on other sites More sharing options...
Wez Posted October 17, 2012 Share Posted October 17, 2012 I would obviously like the best I can buy for my money, but its gone from a remap, to a new standalone, to a top premium product. Still unsure where I'll go from here. What ECU / piggyback you running at the moment, cant see it listed in your build thread. Link to comment Share on other sites More sharing options...
mellonman Posted October 17, 2012 Share Posted October 17, 2012 I would obviously like the best I can buy for my money, but its gone from a remap, to a new standalone, to a top premium product. Still unsure where I'll go from here. what has changed for you wanting a remap,times are hard for everyone dont get bullied into something that you dont want or need Link to comment Share on other sites More sharing options...
Noz Posted October 17, 2012 Author Share Posted October 17, 2012 (edited) What ECU / piggyback you running at the moment, cant see it listed in your build thread. Emanage Ultimate what has changed for you wanting a remap,times are hard for everyone dont get bullied into something that you dont want or need I think I had a stock ECU error when I went for mapping with Ryan originally. A few weeks after mapping the car kept running lean until I reset the ECU and everything went rich. I've changed from 2.5" intercooling piping to 3" with a much larger intercooler. I've ditched the 3" downpipe and 2.5" exhaust system for a 4" downpipe/midpipe and 4.5" exhaust. I also had it mapped on 95ron, not the best idea I know, Ryan did explain this was a mistake but I still pushed 373. Also, the boost controller failed on the dyno. Epic failure. Though it wouldn't of made a huge difference as it wasn't running properly anyway. For a while I checked the ignition when I returned, the car didn't run properly for ages I swapped parts and had white tip spark plugs and all sorts. Disconnected the battery and it seemed to go back to the standard it was when I first had it dyno'ed. Installing an AFR gauge showed it was running very rich. I took some advice and removed the smallest amount of fuel from the RPM range that was worst affected. This stopped the misfire, and pointed me towards the fact I need a remap. The car clearly was't in the best condition or prepared for a piggy back tune. I'd flooded the engine days before with a loose hose from the TB on top of the engine. This I think may have contributed to some issues snow balling to affecting the dyno day. Ryan did try his best with the poor running engine and a failed boost controller, it just wasn't my day as someone drove into me leaving whifbitz garage wrecking my rear bumper moments before getting it mapped. A remap was always on the cards, my dyno print out shows how hectic the power comes in on boost. The curve is strong until the misfire, I think the stock ECU just didn't want to play. Maybe there is still issues with ignition, I've had no more white plugs though. Either way, I've expanded flow to and from the engine and I'd like to see how well it can do. With 440cc injectors Im sure it has lots of potential even with stock compression. I'm fitting alot of new cosmetic stuff and having bits sprayed so this is the last thing on the list and then it's done for a while as I build the new engine and spend some time enjoying it. Im in no rush for power, but it's always nice to have targets! I will need a new ecu or a remap of the old one in the next couple of months. Still undecided. Edited October 17, 2012 by Noz (see edit history) Link to comment Share on other sites More sharing options...
Ian C Posted October 17, 2012 Share Posted October 17, 2012 If you decide to sell your EMU drop me a PM Link to comment Share on other sites More sharing options...
Noz Posted October 17, 2012 Author Share Posted October 17, 2012 What are they worth? Im tempted to take it out now Link to comment Share on other sites More sharing options...
mattdavies Posted October 17, 2012 Share Posted October 17, 2012 After looking on the 2bartuning website I noticed they can map the Link ECU Link to comment Share on other sites More sharing options...
Wez Posted October 17, 2012 Share Posted October 17, 2012 After looking on the 2bartuning website I noticed they can map the Link ECU Ryan has lots of experience with Link ECUs Link to comment Share on other sites More sharing options...
