Automatic Transmission Oil leak
mihai
Is the first time when is leaking oil.. a lot of transmission oil. the supra is single turbo with 440 hp, the gearbox has no oil cooler, the oil smells burntand is quite brown.... the gearbox is working well it shifts smooth and the 1,2,D,N,R changes are normal. It is this broken?
Thank you very much for your time!
So are you asking if it's still ok to drive? Or are you asking where it's leaking?
Obviously, if it's leaking you need to at least have a look to see where as that would imply something may be broken.
It may be a small leak but it might cause further problems if left. Get under it and give things a clean and maybe at least try to locate the leak.....!
I will not drive the car like this, the leak looks like is comming between the engine and gerabox and is not a small leak.... it´s from today 2 hours and i was driving normaly, yesterday i did crazy thing with the car. :( (maybe is time to move to manual R154)
How do you know its coming from your transmission? If its coming from between your gearbox and engine it could be engine oil. What level is your autobox fluid at? is it losing fluid? What about the cooler in the rad, is it in good nick as if it were to develop a leak I would look there first as the lines are quite exposed if your not running an undertray for example.
The engine oil level is perfect and it can´t be engine oil because it smells different, the smell of the gearbox oil from the stick indicator is the same as the oil from the leak. the level in the transmission oil is lower but it still have 70% of the oil. I will add photos. :D
Is it a UK or J spec car? Because UKs should have a seperate bigger cooler. If youve gone single then having a bigger cooler is a definate must as the radiator cooler just is not good enough. You should not need to go manual as there has been many people running 500bhp+ on the stock autobox me being one of them. Its easy for the rubber oil lines from the box to the cooler to become brittle and crack which im guessing is what happened, as for the oil being brown this is not good either.
I would reccomend you do the following -
Drain all the fluid
Replace the filter in the transmission with a new one
Top up with fresh fluid
AND GET A COOLER!
Drain all the fluid
AND GET A COOLER!
And fix the leak ;):)
If its between engine and box it could be the front main seal in the box, if the
ATF is really bad i'd be inclined to get the box out and do a proper flush on it
inc the T/C
Drain all the fluid
AND GET A COOLER!
It´s a Jap spec, Thank you for your recomandation i will do this!
  • 4 months later...
Not again...... the same big leak of the transmission oil, after i change the gaskets, the filter, cleaned the gearbox, new oil, new crank bearing, custom made chromium ring of the oil pump, etc. This was 2 months ago and i drive it 300km... i know it can´t be somthing expensive but i start to hate the auto box.
what is the breather on top of the gearbox? can it be a oil line that broken? :( I am so sad.
  Dnk said:
Was the correct amount of fluid in it ie: not overfilled
It was running perfect 2 months and yesterday night disaster. I had to drive it (slow) with no oil at all 15mph to get it to this respected mechanic in town who repaired last time. Is frustrating but i hope he will find the problem today. The gears change are late than kicking when get in gear.
  • 2 years later...
