Kaan W Posted October 11, 2012 Share Posted October 11, 2012 I have a UK spec car with UK spec rear lights but want to swap to facelift rear lights. I have read that wiring needs to be changed but what exactly needs changing? Is there a simple guide to follow or someone thats done this point me in the right direction? Also is it against the law not to have rear fog lights fitted? Thanks Quote Link to comment Share on other sites More sharing options...
Digsy Posted October 11, 2012 Share Posted October 11, 2012 I have a UK spec car with UK spec rear lights but want to swap to facelift rear lights. I have read that wiring needs to be changed but what exactly needs changing? Is there a simple guide to follow or someone thats done this point me in the right direction? No, they should plug straight in. Also is it against the law not to have rear fog lights fitted? Yep. You will need to convert a pair of brakes to also work as a fog. Thankfully 99.9% of MOT stations don't observe the rule about the minimum distance between the fog light and brake light, so its fine to make a rear fog light this way. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 11, 2012 Share Posted October 11, 2012 Heckler sells a device that converts two of your rear lights to fog lights. The device basically uses a set of brake lights as fog lights, but when fog light isnt on they are still brake lights Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 11, 2012 Author Share Posted October 11, 2012 No, they should plug straight in. Plug straight back in and work with no issues? Im sure ive read that all light wiring is different and you cant just swap between j spec, uk spec, facelift, pre facelift. Having some facelift led rears made up by heckler but dont want to get them and they dont fit or work because the wirings different. Quote Link to comment Share on other sites More sharing options...
Littler Posted October 11, 2012 Share Posted October 11, 2012 They wouldn't work surely as the 2 inside lights are fog lights on a uk where as they are reverse lights a set of facelifts? Unless it's a case of just fitting the bulb holders in different positions to make them match the lenses? lol Quote Link to comment Share on other sites More sharing options...
heckler Posted October 11, 2012 Share Posted October 11, 2012 they will fit with no altering to the wiring - on my car i've had facelift, UK spec and Pre facelift! - all plug and play. Quote Link to comment Share on other sites More sharing options...
Littler Posted October 11, 2012 Share Posted October 11, 2012 ahhh live and learn Quote Link to comment Share on other sites More sharing options...
heckler Posted October 11, 2012 Share Posted October 11, 2012 obviously - on a uk spec lights the plug has a 6th wire for the fog light, which is an empty slot on the JSpec loom so the JSpec's wont have a fog light. Quote Link to comment Share on other sites More sharing options...
Digsy Posted October 11, 2012 Share Posted October 11, 2012 they will fit with no altering to the wiring - on my car i've had facelift, UK spec and Pre facelift! - all plug and play. Me too. Quote Link to comment Share on other sites More sharing options...
