question about air con in the supra
tina n paul
Hi all , i have a question , basically my aircon works but i noticed that the supra doesnt have an air con fan ?
thus aircon is next to useless unless the car is moving ,?
I no i can buy slimline fans, and fit them to help .
i havent looked to see if it would actually fit ,and i would need to wire it in a certain way via switch ,
But am i right in thinking this is factory standard no air con fan ??,,to help condense the air con rad faster ?
any help appreciated cheers paul .
  straightsix said:
There's no fan air con fan on an NA. The only reason an extra fan is fitted to a TT is to help with engine cooling due to the extra engine load when running the AC. It's nothing to do with condensing at all. Your AC will work fine.
:yeahthat:
An I can confirm my car still blows out ice cold air sitting in traffic on a 30c day, well I do live in London!!
  tina n paul said:
but is hes supra an na or tt ?
  straightsix said:
It makes no difference to the function of your aircon. See my explanation above dude :rolleyes:
Yep, his answered your question above :)
An just for clarifition I have owned both a NA & TT and doesn't make a difference, though the NA does seem a little colder!
How does rain dry up on the pavement on a dull day? Surface area and air. God doesn't get a big fan out.....!
Science. Not just on Brainiac.
I think Toyota's boffins know what they're doing. Even on cars with electric fans, they don't start running just because the air con is switched on. Ever noticed the big fan on the back of your fridge? Nope, because it doesn't need one!
Instead of worrying about why your air con is working correctly and as Toyota intended, try working out how a bumblebee can fly!
Edited by straightsix (see edit history)
  tina n paul said:
ok if above is correct ,
how on earth does it condense the air if theres no fan ? evry car ive ever driven and thats a few
need a fan to condense air properly
That big fan in the engine bay covered by the shroud? Thats how it works. The a/c rad is in front of the main rad. When a/c is turned on the ECU ups the idle to absorb the load of the compressor and to increase air flow through the a/c rad.
yeah exactly wot swampy said also the viscous fan unit is temp sensative the internal resistance of the viscous fan hub changes as the radiator temps increase, thus self regulating, the condensor upps the temp of the air being sucked thru the rad and the fan then spins more actively, so as you sit in traffic and the temps increase the fan spins more actively and thus cools more
There should be a AC condenser fan fitted in front of the AC rad its a metal one,I have a TT but i'm sure my NA had one aswell.
