MannDuo Posted October 10, 2012 Share Posted October 10, 2012 Anyone here had any problems with mildew/mould in there car when it has been left sitting? The 'supe has been sitting for around 16 days now, which as far as 'sitting' goes isn't a long time at all, but there is a serious amount of mildew/mould all over, well, everything. I was genuinely shocked when I went out to clean it, it's absolutely covered, the steering wheel you can't even tell is supposed to be black it's so bad. You would think it's been sitting damp for years looking at it! I'll see about uploading some pictures. This is also why i'm saying mildew/mould, as I don't really know which it is. So anyone else here have issues as bad as this in such a short period? If so are there any common places on the Supra that can let moisture in? Cheers for any help. Lee Link to comment Share on other sites More sharing options...
Dnk Posted October 10, 2012 Share Posted October 10, 2012 The air temp is dropping now so you will suffer with condensation inside the car and leaving it for a long period of time isn't advisable Link to comment Share on other sites More sharing options...
j_jza80 Posted October 10, 2012 Share Posted October 10, 2012 Check that the moisture barriers haven't been removed from behind the door cards. Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 Pictures really don't show how bad it is, but the best I could get: Link to comment Share on other sites More sharing options...
TubbyTwo Posted October 10, 2012 Share Posted October 10, 2012 I would advise getting some mositure traps in the car if its going to be left for any length of time. A steam cleaner would probably get rid of most that, but I reckon the wheel will be stained. Might be lucky with some strong APC and a scub. Good luck. Link to comment Share on other sites More sharing options...
Ian W Posted October 10, 2012 Share Posted October 10, 2012 As above really, get some moisture traps. If the car is garaged you could also leave the windows open a smidge for ventilation. Usually helps massively. Link to comment Share on other sites More sharing options...
Josh Posted October 10, 2012 Share Posted October 10, 2012 That's really bad. I'd be stunned to find my interior in that condition after leaving it. Hope it all cleans up ok! Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 10, 2012 Share Posted October 10, 2012 If the car is in shade or shadow for most of the day then I'd recommend moving it somewhere it can get at least a few hours direct sunlight. Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 The car is kept in a car pool kinda thing, basically a garage without a door. I was gobsmacked when I went to get it out to give it a clean and a run, I can't believe how bad it got in so little time, which is baffling me as to what could cause it to be so bad. I checked the seals before, from what I can tell they look absolutely fine and have good contact when the doors are closed. Other than that I'm pretty oblivious as to where I could look. Does anyone have a run down of most, or all the seals that I would need to check? I have looked at all the obvious ones and nothing seems amiss, I will probably replace them anyway just incase. Link to comment Share on other sites More sharing options...
j_jza80 Posted October 10, 2012 Share Posted October 10, 2012 The car is kept in a car pool kinda thing, basically a garage without a door. I was gobsmacked when I went to get it out to give it a clean and a run, I can't believe how bad it got in so little time, which is baffling me as to what could cause it to be so bad. I checked the seals before, from what I can tell they look absolutely fine and have good contact when the doors are closed. Other than that I'm pretty oblivious as to where I could look. Does anyone have a run down of most, or all the seals that I would need to check? I have looked at all the obvious ones and nothing seems amiss, I will probably replace them anyway just incase. Check that the moisture barriers haven't been removed from behind the door cards. Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 I'm going to assume you mean a barrier actually behind the doorcard? Sorry I completely missed that, I will go and check now. Link to comment Share on other sites More sharing options...
Dnk Posted October 10, 2012 Share Posted October 10, 2012 Is it just on the steering wheel and gearshift ? Link to comment Share on other sites More sharing options...
dan294 Posted October 10, 2012 Share Posted October 10, 2012 Check under your boot carpet as well, in case the boot seal leaks. Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 (edited) Is it just on the steering wheel and gearshift ? Nope. Centre console, seats, seat belts, rear seats are completely covered. Pretty much the whole car except the boot which seems spotless for some reason. Just took passenger side doorcard off, and the moisture barrier (Which I assume is the plastic sheeting) Is indeed there, does have holes in it though? And it's clean/dry under the boot carpet. *Just took both doorcards off completely, drivers side barrier is just a complete mess, it's torn to shreds and might as well not be there. So currently duct taping that up the best I can until I can get some decent material. Passenger side turns out to have more than just "some holes" so is also getting the duct tape treatment! Edited October 10, 2012 by MannDuo (see edit history) Link to comment Share on other sites More sharing options...
Ian W Posted October 10, 2012 Share Posted October 10, 2012 You want more ventilation, not less! I'd definitely suggest checking your boot etc for water getting in. Heater matrix okay? Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 Haven't checked heater matrix, literally hadn't even thought about it. Door barriers are sorted, seals look fine, the car has been completely cleaned, 3 times. I was on a mission to block any where moisture can get in, without even realising like you said, that the car would need ventilation as well. Seriously, I should not be allowed near things. At least the mould/mildew doesn't smell! That's a bonus I guess. I'l check the heater matrix, then I guess it's a waiting game to see if/when it comes back Link to comment Share on other sites More sharing options...
Ian W Posted October 10, 2012 Share Posted October 10, 2012 With mould that bad I'd be expecting to find stagnant water somewhere in the car. Carpets all dry? (Particularly in the passenger footwell) Link to comment Share on other sites More sharing options...
AndrewOW Posted October 10, 2012 Share Posted October 10, 2012 You have a leak there, as you wouldn't get that amount of mould/mildew without some serious damp problems, IMO. When the car is parked in the pool (ironic really), is it safe enough to leave a window slightly open? My mum owned a Mini 1275 which was left for months after my sister ruined it (never checked the oil), and that eventually grew fungi and mushrooms throughout, and that was only from a little leak in the roof. Link to comment Share on other sites More sharing options...
MannDuo Posted October 10, 2012 Author Share Posted October 10, 2012 With mould that bad I'd be expecting to find stagnant water somewhere in the car. Carpets all dry? (Particularly in the passenger footwell) Yeah carpets are bone dry. Once I had finished cleaning I went searching for damp spots/water, couldn't find any in the car. I will be doing a more thorough search in about an hour or so though, need one hell of a shower first! And like you said, that is a serious amount of mould, so there is probably something already in the car causing it. Link to comment Share on other sites More sharing options...
Dnk Posted October 10, 2012 Share Posted October 10, 2012 (edited) Have a look on amazon/ebay etc and get your self an incar dehumidifier I 'd also get one of those cans you let off inside the car with the ac/on recirc doors/windows shut, they kill lots of bacteria everywhere but mainly in the air vents etc. Edited October 10, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
TubbyTwo Posted October 10, 2012 Share Posted October 10, 2012 get a few of these in there if your going to leave it for a while. http://www.ebay.co.uk/itm/4-x-SCENTED-INTERIOR-DEHUMIDIFIER-ABSORB-MOISTURE-DAMP-MOULD-BNew-/120870318630?pt=UK_Home_Garden_Hearing_Cooling_Air&hash=item1c246eb226 Link to comment Share on other sites More sharing options...
spikedjack Posted October 10, 2012 Share Posted October 10, 2012 I'd stick some form of moisture absorbent in there for a while, silica gel or similar Link to comment Share on other sites More sharing options...
AndrewOW Posted October 10, 2012 Share Posted October 10, 2012 Or maybe try a bowl of baking soda too. I assume a leaking heater matrix could be a cause, but wouldn't the front footwells be wet? Link to comment Share on other sites More sharing options...
Shane Posted October 10, 2012 Share Posted October 10, 2012 I reckon, at some point near to the time you parked it up you had food in the car. I've noticed when my little girl has been in her chair strapped in the back of the car and been eating something, the mould spaws quickly appear around her straps and the seat cover when its been parked up in damp conditions, especially if its something sticky/sweet. The good news (well for us at least) is that you can get rid of it quickly. We used dettol wipes and that got rid of most of it, but the spaws on the seat belts took a bit more effort as it seemed to be really engrained into the threads. Link to comment Share on other sites More sharing options...
MannDuo Posted October 11, 2012 Author Share Posted October 11, 2012 No food in that car that I know of apart from sweets, lol. But it is now all clean looking but just doesn't feel nice to sit in due to knowing how bad it was. Haven't been able to find any damp patches or water, and the heater matrix is fine. The car will now be getting stripped out, I was wanting to dye the carpets anyway so I now have an excuse to take them out. Hopefully when everything is removed I will be able to find the culprit. Until I get the time to remove everything, I have bought the moisture boxes linked above, and will be keeping them in the car, and I will probably disconnect the battery and leave the windows slightly open (Car automatically locks and shuts windows) as it is indeed safe to do so. Thanks for all the responses guys, hopefully I will have it properly sorted soon! Link to comment Share on other sites More sharing options...
