Guest Aus80 Posted October 8, 2012 Share Posted October 8, 2012 is there any way to remove the oil filter neck? i am running a oil cooler but want to piss the neck off as it goes up to high towards the inlet plenum, i plan to run a 2nd set of injectors under the plenum and was just wondering it any one has mounted the oil filter straight to the block with some sort of remote kit ect? thanks Quote Link to comment Share on other sites More sharing options...
Al Massey Posted October 8, 2012 Share Posted October 8, 2012 Yes you can run it from the block You need an adapter though, Paul Whiffin does one Quote Link to comment Share on other sites More sharing options...
Al Massey Posted October 8, 2012 Share Posted October 8, 2012 Here you go, this is what you need http://whifbitzperformancetuning.co.uk/toyota-supra-engine-components-bottom-parts-garage-whifbitz-p-14849.html I may have a spare one, ill have to check later but they are only a few quid Quote Link to comment Share on other sites More sharing options...
