SRD Built Autoboxes
Lee P
Will be offering a range of built auto boxes now :)
There will be different stages depending on requirements and I will try and provide HP rating in the near future.
These will idealy be built from your original units but I will try to have 1 box here and to work on exchange.
Torque Convertor rebuild £240
Standard transmission Rebuild £1250
Stage 1
Fully rebuilt transmission
reprogrammed valve body
new boost valve
Gaskets & seals
Bushings
Filter
£1760
Stage 2
new boost valve
Stage 1 clutch Plates
Gaskets & seals
Bushings
Filter
£1890
Stage 3
Fully Rebuilt transmission
Reprogrammed valve body
New boost Valve
Dual Ring accumulator pistons
Stage 1 Clutch plates
Gaskets & Seals
Bushings
Filter
£2390
Stage 4
reprogramed valve body
new boost valve
Dual ring accumulator pistons
Billet forward clutch piston
Billet intermediate hub with heavy duty sprag and drive shell assembly
Stage 1 clutch plates
Gaskets & seals
Bushings
Filter
£3900
PI High Stall Torque converter £1040
Prices are plus removal and installation if required
We advise the use of SRD gearbox coolers with all transmissions, two are required on cars running over 500hp.
Thanks
Edited by Lee P (see edit history)
  • Replies 61
Would need to see power figures then before i decide. I take it the modifications you do to the box are that of titan/ boostlogic ect? Proven results are obviously not in your favour as its a new product but i would use you all day long. Have you got a box to put in a car yet or a car running it as we speak?
what would be the max bhp what could be used on this box stage 4, could it handal 1500bhp for drag or is that just a no no.
For that kind of power you would need a TH400 but the drivability isn't very nice so would really be drag only.
We are building a stage 4 box now, we want it to hold 700-800ftlbs
Yeah 3 speed and you shift manually. You have to modify the trans tunnel for it to fit.
Needs some parts as well to fit it.
I thought you had to mate a j3 bellhousing to it also...
I would have gone th400 as driven a few cars with this box and simular and it felt normal. But also heard for all the mods needed to build it up and fit would cost double of the getrag.
It does need a different bell housing yes.
