supra steveo Posted October 7, 2012 Share Posted October 7, 2012 right guys for those of you that dont know i am hoping to do a conversion on my aerotop so it will be a twin turbo, 6 speed , its already been converted to an N/A 5 speed so the sub tunnel is already modded , thing is ive never took the engine out the supra before so i am kind of bricking it i should be back with the can in about 6 weeks so can start picking stuff up then few things i need to know what goes inbetween the engine and gearbox clutch wise ? ive found a oem clutch but need a flywheel if ive never done this before am i biting off more than i can handle and should i just look for somewhere to fit the kit ive bought ? Link to comment Share on other sites More sharing options...
Jos Posted October 7, 2012 Share Posted October 7, 2012 I think you'll need a dual mass flywheel,longer flywheel bolts, maybe the release bearing and rings if they didn't come with the box, and a propshaft. There is always a first time for everything but if you don't have the space and tools for this I would let someone fit it Link to comment Share on other sites More sharing options...
mclarenross Posted October 7, 2012 Share Posted October 7, 2012 Hi mate, I've got an engine crane you can borrow if you decide to go ahead with the project. Link to comment Share on other sites More sharing options...
supra steveo Posted October 7, 2012 Author Share Posted October 7, 2012 Hi mate, I've got an engine crane you can borrow if you decide to go ahead with the project. Cheers for the offer mate but I might be doing this down the country in Suffolk I think you'll need a dual mass flywheel,longer flywheel bolts, maybe the release bearing and rings if they didn't come with the box, and a propshaft. There is always a first time for everything but if you don't have the space and tools for this I would let someone fit it got a prop and a Carbonetics diff and drive shafts Link to comment Share on other sites More sharing options...
Jos Posted October 7, 2012 Share Posted October 7, 2012 got a prop and a Carbonetics diff and drive shafts Nice!, then I suppose all you need are the missing clutch parts, if you have an epc you can find the part numbers there. Link to comment Share on other sites More sharing options...
