removing calipers instruction?
RB-GTE
So I rented a Eastwood Fender Roller to flare my front fenders, so my new wheel setup doesn't rub at the front.
As I started doing it I noticed that the rolling machine hits the caliper. I am only able to do the front end not the whole fender.
So it looks like the only way to use this machine I need to remove the front calipers.
Any instructions on how to remove the TT calipers? Couldn't find anything.
I have no experience with it but I would imagine it should be pretty straight forward.
The rotor and everything else needs to stay on.
cheers
Edited by RB-GTE (see edit history)
As above. Brakes aren't something to mess around with unless you know what you're doing. My advice would be to get a mobile guy out to pop them off and back on for you if you intend on rolling the arches yourself. Mighy cost a call out fee and/or an hours labour, but at least you know you ain't gonna crash and die at the end of it!
Here is the brake system for you to refer too but if in doubt get help
When you remove the caliper do not let it dangle on the brake hose, tie it up
out of the way using cable ties, you wont need to undo the brake hose thus no
need for bleeding the brakes when you finish.
Also don't let anyone press the brake pedal for obvious reasons :) while the
calipers are off the discs !!
BR.pdf
undo the 2 big 17mm bolts at the back of the caliper.
slide it off
cabble tie it up so you dont have it dangling around on the brake line.
while off gently bush back the pistons a little bit.
slide it backinto place
tighten the bolts the a a soft shade oh knuckle white
pump pedal.
Got one of them off no problem.
for the 2nd front I did, it wouldn't slide off the rotor. Actually when I undid the two bolts the rotor was also loose. I had to remove the whole caliper/rotor. The caliper for some reason wouln't budge or get off the rotor. Why is this, what's stopping it?
I'll be getting some new slotted rotors, new brake pads, and painting the calipers soon. So wanted to know before hand :)
thanks
You have to ease the pads apart before you unbolt the caliper, if they pads wont
push back away from the disc then the caliper needs a closer inspection.
Remove the pads and look at the condition of the outer seals that fit round the
pistons, if you have original calipers or calipers that are 15 + years old then i
strongly recommend they are stripped and rebuilt
Which calipers do you have, 4 piston or 2 piston ?
thanks
If the disk has a lip on the outer edge, it'll stop the pads getting past it, so as Dunk said, prise the pads apart first.
The Big TT brakes
4/2 piston combo
