matthewswinimer Posted October 6, 2012 Share Posted October 6, 2012 Hi there guys iam wondering why my car is running so rich while cruising it bouncing around 10.5 while cruising at a steady speed. Is this normal I thought it was supposed to run around 14.7 Link to comment Share on other sites More sharing options...
JasonR24 Posted October 6, 2012 Share Posted October 6, 2012 Hi there guys iam wondering why my car is running so rich while cruising it bouncing around 10.5 while cruising at a steady speed. Is this normal I thought it was supposed to run around 14.7 O2 sensor? Link to comment Share on other sites More sharing options...
matthewswinimer Posted October 6, 2012 Author Share Posted October 6, 2012 O2 sensor? No mil light Link to comment Share on other sites More sharing options...
Tyson Posted October 7, 2012 Share Posted October 7, 2012 No mil light As long as there is a signal coming from the O2 sensor it won't flag an error code but it might be covered in crap causing you to run rich. Clean the O2 sensor and see if it makes a difference, it won't cost you anything so worth a try. Link to comment Share on other sites More sharing options...
matthewswinimer Posted October 7, 2012 Author Share Posted October 7, 2012 As long as there is a signal coming from the O2 sensor it won't flag an error code but it might be covered in crap causing you to run rich. Clean the O2 sensor and see if it makes a difference, it won't cost you anything so worth a try. Ok I'll try that send let ya know Link to comment Share on other sites More sharing options...
matthewswinimer Posted October 7, 2012 Author Share Posted October 7, 2012 Ok I'll try that send let ya know Took it out looked fine. Cleaned anyways. Installed still the same any other ideas??? Link to comment Share on other sites More sharing options...
Lee P Posted October 7, 2012 Share Posted October 7, 2012 You need to try a new sensor, the old one may look ok but could still be faulty. Link to comment Share on other sites More sharing options...
Noz Posted October 7, 2012 Share Posted October 7, 2012 Electronic components can fail without damaging the exteroir of the body, internal components could be failed and you wouldn't realise, which is why fuse's have clear glass for example. Lee is right a good looking sensor doesn't mean it's functioning correctly. Link to comment Share on other sites More sharing options...
Nic Posted October 7, 2012 Share Posted October 7, 2012 Do a diagnostic check of the O2 sensor, see here http://www.mkivsupra.net/vbb/showthread.php?35940-Narrowband-O2-Sensor&highlight=oxygen Link to comment Share on other sites More sharing options...
