Flywheel removal
RHochreuter
Hey guys,
How do you remove the 6 flywheel bolts?
Obviously the flywheel spins when applying some Nm to the flywheel bolts :)
What is the best solution?
I have the following ideas, but i don't know if it will work:
1) Ask a friend to counter the movement of the crank by locking the crankshaft from the front
2) Fabricating a tool that locks the flywheel teeths
When I removed a Nissan note flywheel I placed a double end open spanner one end in the ring gear teeth and the other end on a notch sticking out the engine block, it locked the flywheel to undo the bolts. Primitive I know but it done the trick. Not sure it will work on your engine but the ideas there
