dive_popo Posted October 3, 2012 Share Posted October 3, 2012 Hi, I bought some time ago from RobD , a ATI crank pulley, didn't had time to install it immediately, and i decided to do it last weekend. Unfortunately it wont fit, the fixation hole in ATI pulley is smaller than the one in the stock pulley and it wont work... Any suggestions ? Anybody got an issue like this ? What should I do ? Link to comment Share on other sites More sharing options...
David P Posted October 3, 2012 Share Posted October 3, 2012 They are tighter than a good Saturday night. Boil the centre component in oil, then fit it whilst still hot. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted October 3, 2012 Share Posted October 3, 2012 Split the hub from the damper and heat it up I did mine with a heat gun, as David said fit whilst hot. Link to comment Share on other sites More sharing options...
David P Posted October 3, 2012 Share Posted October 3, 2012 Both systems of heat will expand the hole enough to go on, but should you decide to use dry heat be careful, as to much heat will result with front oil-seal melt-down. Link to comment Share on other sites More sharing options...
dive_popo Posted October 4, 2012 Author Share Posted October 4, 2012 ok will try this thank you a lot guys !! Link to comment Share on other sites More sharing options...
