Geo Posted October 2, 2012 Share Posted October 2, 2012 I've penciled in a coolant and oil change this wknd, but was to just run over some things first? I've done a search and there is loads of ways to do it, one being using the drain plug on the block. So would this still be efficient enough When doing the coolant - would this method remove 3/4 of the coolant? 1. Take off Rad Cap 2. unscrew bottom right drain plug 3. Yank off Bottom Rad Hose(to be replaced with SRD Bottom hose) 4. Catch all coolant 5. Empty Expansion tank 6. Refill from Rad, pouring slowly to stop air bubbles getting in. 7. Fill expansion 8. Start car run for 5mins with Heating on Max cheers guys Quote Link to comment Share on other sites More sharing options...
hodge Posted October 2, 2012 Share Posted October 2, 2012 If your taking the bottom rad hose off, fill it from the back of the engine like I explained, or you could be 1 very unhappy and angry hulk. Quote Link to comment Share on other sites More sharing options...
