Exhausts
RobD
I'm getting a carbon diffuser in the near future but ATM I have an HKS Super Dragger, I really like the look of where the exhaust kicks up at the bumper as to coming out straight!
Any suggestions of what exhaust I should go for?
Rob
Could do you a swap for a dragger AJlittler? :D
I knew I should've bought that of Stuart! :(
Lol, have to say I'm very happy with it, but to go with going single I'm making a quiet exhaust with an electric valve cutout to a 4" dump pipe so keep an eye out for the for sale thread ;)
Is yours lowered? It's even worse if your car it is lol, I have 2-3" clearance ish from the ground, I really have to avoid speed bumps!
Exhausts such as the Blitz NUR take an almost direct line from the 2nd cat to the bumper exit which mean they have to hang lower to clear the underside of the car so ground clearance can be an issue, other aftermarket exhausts follow the same route underneath the car that the stock exhaust takes which means they may not flow quite as well but give much better ground clearance.
