TubbyTwo Posted October 4, 2012 Share Posted October 4, 2012 Ian/Alex at some point If I was to come up to where you guys are, would you mind have a quick look over the seqentional system? there is many beers/food etc in it. Would be massively gratefull, seem to have some 1st turbo boost issues that come and go, it seems to bog down and I dont get the surge it should do. after the change over however it flies, but not as hard as it used to. Instead of spending hours and hours and not really knowing what im looking for, would be great if you knowledgeable chaps could help?? Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 4, 2012 Share Posted October 4, 2012 Beer and food is a good bribe I work shifts so my availability for such shenanigans is limited to weekdays daytime when I'm not at work Also I might have a pressure tank lying around. Good luck swapping it, it's a nightmare to get at Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted October 5, 2012 Share Posted October 5, 2012 Thanks Ian, I have few days holiday going spare so once I have checked anything else I can think of I will give you a shout if thats ok. I swapped the restrictor ring position last night to between the 1st and 2nd cat, so will wipe and reset the boost controller and see if that makes a difference, no stored error codes, all the IC pipes are tight etc. Massive help, thanks Quote Link to comment Share on other sites More sharing options...
