twin turbo pressure tank bypass ???
chris.neale
Hi everyone,
I'm new to this forum and wonder if you can help me. I have recently bought a twin turbo supra after many years of wanting one. it doesn't seem to be holding boost correctly. I have been checking all of the vacuum hose and noticed that the pressure tank seems to be bypassed. Would this cause the car not to boost correctly is there any benefit to by passing it ? I have uploaded a standard picture and drawn badly a vacuum hose on it as i can't get a camera down there. The other two pictures, the picture of the blue vacuum hose is going to the pressure tank the black vacuum hose with the screw in is coming off it. I don't think this right but any advice would be grateful![ATTACH=CONFIG]158405
Edited by chris.neale (see edit history)
Also, the charcoal filter has been removed, this is not a problem as long as the fuel tank vent pipe has been blocked as well as the vacuum, if not the car will waft of petrol fumes.
I would recommend you have someone who knows Supra's take a look at it, if there are three bodges that can be spotted in those limited view pics, odds on there will be more.
I will thanks. I live in Norfolk so there's not many garages that know supra's inside and out. Can anyone suggest a good supra garage? I have been to a "performance garage" where the dyno the car and it produced 304 bhp and 292 lbft. they said it seemed to be OK. To be honest with all the basic BPU been already done i thought it would produce more?
That's a very poor power figure for a TT let alone a BPU one! You should be in the 370-420 region, best get it looked at as stated :)
As everyone have already mentioned, it needs to be checked because at around 300bhp that's n/a spec I think.
Didn't think you can bypass the pressure tank because without it, correct me if I am wrong you will get boost issues. You can bypass the sequential system by doing the TTC.
First off, your picture with the blue hose labelled "To pressure tank" is odd as that pipe should be connected to the BOV on the left of the picture. So you've got no recirculation when you come off boost.
Secondly, the pressure tank, from what I've worked out, keeps the intake air control valve and the exhaust bypass valve open under certain conditions even when there isn't any boost pressure being generated by the turbos to work them. For example, gear changes, or coming off the throttle but still being above 4000rpm. The response on re-accelerating would be very poor if the second turbo had come offline and the first had to spin up to produce the boost to open it all up again.
So the tank being bypassed isn't ideal, and the BOV should be plumbed in, but neither of them should result in the car being down in power overall. However it does indicate that there is probably another plumbing issue in there somewhere :)
-Ian
Hi Guys,
thanks for all your advice. Ian i have a hks bov installed which is connected as per the pictures. i was going to take the old bov out and plug the holes. Yeah your all properly right i need to sort the " plumbing" out as per the guides attached . I will have a go myself, if not as suggested I will take it to keron or whiftbiz when i get a full day spare. The guy in the garage reckon my greddy boost garage is wrong as it was only show .04-.05 bar boost max but as you all said the car should be boosting better then it is.
