RB-GTE Posted September 28, 2012 Share Posted September 28, 2012 (edited) For my new wheel setup, a little fender rolling/pulling will be required. I will see next week when I test fit my new wheels. The rears have already been rolled flat. Is it better to keep the lip rolled back againts the inside, and just pull the fender this way? Or have it cut? I figured if I leave it rolled it would help them have a stronger and better structure. The fender edge would seem thin and fragile if I were to cut the lip off? It won't be getting pulled too much, at most about 0.5" For the fronts, which are stock, I never paid too much attention to them. Do they also have a lip from the inside? or is there nothing there and I need to have them pulled. I understand the paint will crack, which I'm fine with since the car EITHERWAY is getting the quarters/doors painted, since the paint is mismatched to the hatch colour. Edited September 28, 2012 by RB-GTE (see edit history) Quote Link to comment Share on other sites More sharing options...
Al Massey Posted September 28, 2012 Share Posted September 28, 2012 You could flare the rear arches since they have already been rolled, you may get half an inch if someone knows what they are doing? And if done properly the paint won't crack Where are you located? If you need anymore advice I roll arches and have all the equipment Quote Link to comment Share on other sites More sharing options...
