Exhaust Fitting Help Please!
SarahJon
Hi,
I've got a 1994 stock TT and wanted to replace the stock system from the catback just to get a bit of a nice purr as opposed to stock silence :)
I have bought a second hand Whifbitz 2.5" system. I know that on Whifbitz site it states that this is designed more for the NA but I did some research on here and found a few threads where it was stated that fitment on NA's and TT's was the same from the catback (moral of the story - should have gone from what it said on Whifbitz site!!) and my engine is and will remain stock so thought that the smaller pipe wouldn't be a problem at all from an air flow perspective.
We're now trying to fit it and it won't fit over the little bit of pipe that extends from the cat :(
Is it that there are differences between the NA and TT from the cat back that I didn't find out about or is there something a little bit amiss somewhere??
Not sure whether to get a decat pipe and solve the problem that way or whether to sell the Whifbitz exhaust on and wait for something definitely TT compatible to come up.
Any help or feedback would be welcomed as I'm a bit confused about why it won't fit at the moment.
Thanks all,
Sarah
Pic of a standard 2JZ-GTE 1st cat (smaller one nearest the engine) and 2nd cat (longer one that connect to the exhaust), the exhaust mid pipe should bolt onto the flange on the left hand side.
http://mkiv.com/techarticles/downpipe_pics/stock_cats/mvc-006s.jpg
Thanks Nic. I was just about to upload a pic but you beat me to it. If you look on the left where the mid pipe should bolt on, there is a short pipe sticking out past the flange. The prob we have is that this won't fit inside the mid pipe so when you try to bolt the mid pipe on, there is a gap of about 10mm between the two sections.
Get some photos up mate. You may have to weld on some pipe and use the flange I sent you onto the newly welded pipe to extend it. Sound's like the cat has one of those slip and clamp type joiner's rather than 2 bolt flange which all stock systems usually run.
Definately the 2 bolt flange. I'll post a picture in a sec.
Glad your happy with it mate :)
Yep! Been out in it today and the growl is just what we wanted. Doesn't intrude into the car at all but nice and growly from outside the car - perfick!!
We've bought Dean's (tooquicktostop) wheels from him too so once we get those from him in the next couple of weeks then the car will be starting to look a lot better as well as sounding better :)
