RB-GTE Posted September 26, 2012 Share Posted September 26, 2012 (edited) So I removed the incredilby ugly Camry style OEM steering wheel, and replaced with a nice MOMO. What I did was unplug the airbag and removed it, then removed the steering wheel. For the MOMO after hooking up the HORN, the yellow wire/harness for the AIRBAG I just tucked behind the steering wheel hub on the MOMO... since this MOMO has no airbag. This airbag warning light is on the whole time now. I'm wondering what is the best way to get rid of it. http://imageshack.us/a/img841/4091/img20120925205230.jpg Edited September 26, 2012 by RB-GTE (see edit history) Quote Link to comment Share on other sites More sharing options...
Littler Posted September 26, 2012 Share Posted September 26, 2012 Did you disconnect the battery before doing it? As you'll have to do the airbag/ecu trick if not: http://www.mkiv.com/techarticles/airbag_light/airbag.htm Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted September 26, 2012 Author Share Posted September 26, 2012 Yes I definetley disconnected the battery I actually quickly searched up the online instructions since I never changed the Supra steering wheel before. Also I checked out the link on mkiv.com have no idea what I just read, may have to go check for myself to see what the whole AB TC thing is all about. Quote Link to comment Share on other sites More sharing options...
Littler Posted September 26, 2012 Share Posted September 26, 2012 Also just realised you haven't put a new steering wheel on with an airbag, so the connector isn't plugged in, maybe the way you can sort it is by removing the bulb from just behind? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted September 26, 2012 Share Posted September 26, 2012 If you havn't got a steering wheel with an air bag then get a resistor & plug it into your airbag loom. This way your light will function the same as there was a bag in there & you should have no problems with MOT. Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted September 26, 2012 Author Share Posted September 26, 2012 (edited) The new steering wheel has no air bag. It's a 3 spoke MOMO race design. A resistor sounds like a good idea. So it tricks it into thinking there is an airbag plugged in Any idea where I could get one for the MKIV ? I searched and couldn't come up with anything. cheers Edited September 26, 2012 by RB-GTE (see edit history) Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted September 26, 2012 Author Share Posted September 26, 2012 Also just realised you haven't put a new steering wheel on with an airbag, so the connector isn't plugged in, maybe the way you can sort it is by removing the bulb from just behind? That was a though but when I turn the ignition key ON I'd prefer that all lights are operational. Then when the car is started it would shut off. Quote Link to comment Share on other sites More sharing options...
Littler Posted September 26, 2012 Share Posted September 26, 2012 That was a though but when I turn the ignition key ON I'd prefer that all lights are operational. Then when the car is started it would shut off. They all have individual bulbs so you can just remove the airbag light and all the others still work? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted September 26, 2012 Share Posted September 26, 2012 The new steering wheel has no air bag. It's a 3 spoke MOMO race design. A resistor sounds like a good idea. So it tricks it into thinking there is an airbag plugged in Any idea where I could get one for the MKIV ? I searched and couldn't come up with anything. cheers Thats exactly what it does. The only person on here i can think of is hecklor i think is his user name, he does the LED conversion. I'm guessing your in UK? I've had to use them before to get cars threw the NCT test if the clock spring was faulty & bringing on the airbag light. If you have no luck let me know & i will try the lad where i get them & see if he can help. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted September 26, 2012 Share Posted September 26, 2012 Just stick THIS in the airbag connector Quote Link to comment Share on other sites More sharing options...
straightsix Posted September 26, 2012 Share Posted September 26, 2012 If you only had a driver's airbag, you should just remove the bulb as there are no other airbags. If there's no airbags in the car, there's no need for the dash light for the MOT. I'm sure it's going to cause more concern to an observant individual that you have a dash light operating 'normally' for a piece of equipment that isn't there! If you have a passenger airbag you'll need to sort it or the airbag system will not work - ie the passenger airbag won't fire if there's an accident. You should also inform your insurance company as they may see it that you have removed safety equipment. Personally I would have updated with a stock toyota/lexus three spoke airbag wheel Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted September 26, 2012 Author Share Posted September 26, 2012 Yes I have the factory passenger airbag. So inorder for the passenger airbag to work, the airbag connector/resistor is what is basically needed? Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted September 26, 2012 Share Posted September 26, 2012 You should have bought an airbag delete boss kit. You need to get a widget (resistor?) as others have said and then do the 2 wire trick. Even with the widget you will have to do this if you ever disconnect the top dash panel. Just reminded myself I need to reset mine again! Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted September 27, 2012 Author Share Posted September 27, 2012 A airbag delete boss kit is basically a wheel hub with a plug, and the airbag plugs into it so this will remove it? I'm fine with buying one, the MOMO I didn't pay anything I had it laying around. Quote Link to comment Share on other sites More sharing options...
