kniff_666 Posted September 25, 2012 Share Posted September 25, 2012 Just coming to work today and was thinking about changing my exhaust system back to stock (but double decat) Gave it a few beans to see if i still like the noise of my current exhaust (which i still do!) and then clunk. got to work and had a look i don't think there is any welding this back on so i think my mind about changing the exhaust has been made for me! Quote Link to comment Share on other sites More sharing options...
Westy Posted September 25, 2012 Share Posted September 25, 2012 Was the exhaust not blowing before it fell off!? Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 not blowing at all sudden failure and no speed bumps were involved Quote Link to comment Share on other sites More sharing options...
Westy Posted September 25, 2012 Share Posted September 25, 2012 Ahh well, it's the best excuse to upgrade! I have always fancied the Boostlogic system, but can't justify removing a mint condition exhaust for a change in exhaust note!? Quote Link to comment Share on other sites More sharing options...
Wez Posted September 25, 2012 Share Posted September 25, 2012 Looks like someone has exhaust wrapped the whole thing, I would hazard a guess that moisture has got in there and weakened / rusted the join. Quote Link to comment Share on other sites More sharing options...
Littler Posted September 25, 2012 Share Posted September 25, 2012 Wow that's a little odd with how quick it failed lol I have a 2.5" custom single box stainless steel catback for sale for £180 in very good condition if needed... and I'm local Quote Link to comment Share on other sites More sharing options...
Josh Posted September 25, 2012 Share Posted September 25, 2012 Easy decision Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 that might be an option rather than going back to stock. questions being is how loud is it (i am 2nd decat) and is it available now? Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 Looks like someone has exhaust wrapped the whole thing, I would hazard a guess that moisture has got in there and weakened / rusted the join. is it generally not a good idea to heat wrap exhausts then? That heat wrap has been on for about 4months. Question now is should i remove the heat wrap from the rest of it? Quote Link to comment Share on other sites More sharing options...
Littler Posted September 25, 2012 Share Posted September 25, 2012 that might be an option rather than going back to stock. questions being is how loud is it (i am 2nd decat) and is it available now? Yep it's available now and is sat in my garage ready to go, I had it on my TT (previous owner liked a quiet exhaust lol) which meant it was very quiet but I have tested it on an NA and due to the large size of the single box it wasn't too loud at all but had a great sound without the dreaded drone Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 25, 2012 Share Posted September 25, 2012 Corrosion doesn't happen that quickly and must have been going for quite some time, surprised it wasn't pointed out at its last mot. Quote Link to comment Share on other sites More sharing options...
Wez Posted September 25, 2012 Share Posted September 25, 2012 is it generally not a good idea to heat wrap exhausts then? That heat wrap has been on for about 4months. Question now is should i remove the heat wrap from the rest of it? Normally you only wrap the under bonnet components not the whole exhaust, its designed to keep heat in the exhaust and lower under bonnet temps, I cant see it being any real use when under the car. It does increase the risk of cracking and rusting if the car is not used regularly and stored outside as it can trap moisture. Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted September 25, 2012 Share Posted September 25, 2012 Looks to me like it has been welded before. So probably not the first time this has happened. Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 Corrosion doesn't happen that quickly and must have been going for quite some time, surprised it wasn't pointed out at its last mot. I had a fight with a speed bump a while back (ripped the bracket off the pipe behind the back box) and had it welded back on. So inspected the whole thing while if was off. Looked rusted but it was not fragile or blowing etc. strange but it has happened and i need to sort it. I don't think that it can be welded back on either Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 25, 2012 Share Posted September 25, 2012 I can confirm your exhaust is broken Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 25, 2012 Share Posted September 25, 2012 selling my stainless 3" catback for £110 Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 25, 2012 Share Posted September 25, 2012 Normally you only wrap the under bonnet components not the whole exhaust, its designed to keep heat in the exhaust and lower under bonnet temps, I cant see it being any real use when under the car. It does increase the risk of cracking and rusting if the car is not used regularly and stored outside as it can trap moisture. I've noticed several cars at Ten of the Best which have a ceramic coating on the whole exhaust system, presumably to raise exhaust gas pressure. IIRC one was a Subaru rally car. CW would know. But this exhaust wrap is a bad idea under a car. Quote Link to comment Share on other sites More sharing options...
Wez Posted September 25, 2012 Share Posted September 25, 2012 I've noticed several cars at Ten of the Best which have a ceramic coating on the whole exhaust system, presumably to raise exhaust gas pressure. IIRC one was a Subaru rally car. CW would know. But this exhaust wrap is a bad idea under a car. Ceramic coating are very different to wrap, there is no space for moisture to get in plus they act as a protective barrier Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 25, 2012 Share Posted September 25, 2012 The Super Drager is coated to help resist corrosion due to the pipework being mild steel, my system is quite old now but still in very good condition. Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 I can confirm your exhaust is broken is that whats wrong with it? cheers for the confirmation. LOL Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 selling my stainless 3" catback for £110 Condition / age / make of it? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 25, 2012 Share Posted September 25, 2012 Ceramic coating are very different to wrap, there is no space for moisture to get in plus they act as a protective barrier Of course, i think whoever has done this was trying to replicate the benefits of this on the cheap - and ruined the exhaust in the process. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted September 25, 2012 Share Posted September 25, 2012 I bet that sounded cool tho! LOL Has your hearing come back yet? Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 rest of the wrap will be coming off then. Restrict it to under the bonnet only! Live and learn! Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted September 25, 2012 Author Share Posted September 25, 2012 I bet that sounded cool tho! LOL Has your hearing come back yet? sounded great on the downshift but slightly deafening Quote Link to comment Share on other sites More sharing options...
