The Raven Posted September 23, 2012 Share Posted September 23, 2012 Ok i went back to work on my car that has now been off road for nearly a year now. I changed the ECU to try and see if that would sort the massive overfuel issue. I now think they Injecs are stuck open, ALL of them!!!! So i guess that points to an earth? Question is where is the earth to the fuel system? If anyone wants to come and help me fix the car i will provide a full BBQ, Beer, dancing girls, and i may even sell you my soul (dancing girls may not happen, also i think i sold my soul for haribo a few years back but cant remember) Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 23, 2012 Share Posted September 23, 2012 No dancing girls!? I'm out. Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 23, 2012 Author Share Posted September 23, 2012 No dancing girls!? I'm out. I could dance? then again i dont think you want to see that.................. Quote Link to comment Share on other sites More sharing options...
Benjy Posted September 23, 2012 Share Posted September 23, 2012 Just been a little bit sick in my mouth. Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 23, 2012 Author Share Posted September 23, 2012 Really need an answer on this if anyone has one please. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 23, 2012 Share Posted September 23, 2012 The injectors have a common positive feed, fed by the two EFI Relays, the earths all then down to the ECU http://www.internetwork.org.uk/manual/system/ecugte/ecugte3.htm (ignore the resistor pack) Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted September 23, 2012 Share Posted September 23, 2012 Probably not your problem but my car was sat for over a year while I singled it and it had a massive over fuelling issue which came down to a dodgy FCD. But any problem with the map sensor causes huge swings in afr, sensors and the like only had small effects for trimming fuel and didn't really cause big issues. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 23, 2012 Share Posted September 23, 2012 If I knew mate I would come and help you but all this injector stuff is new to me, im used to working on older cars with carburetters and stuff. Im no good at technical stuff like that but I would of guessed changing the ecu would sort it. Hope you get this fixed soon buddy. Quote Link to comment Share on other sites More sharing options...
David P Posted September 23, 2012 Share Posted September 23, 2012 (edited) Check you have wired the MAP sensor correctly. Then check if Parcels-To-Go will deliver the girls? Edited September 23, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 23, 2012 Author Share Posted September 23, 2012 Hang on efi relays? Would those be the ones that you have to wire chop? on a N/A TT swap to the old n.a fuse box? I wonder if i did something wrong wiring that? Quote Link to comment Share on other sites More sharing options...
heckler Posted September 23, 2012 Share Posted September 23, 2012 Hang on efi relays? Would those be the ones that you have to wire chop? on a N/A TT swap to the old n.a fuse box? I wonder if i did something wrong wiring that? EFI relays only provide the postive feed - the ecu controls the injectors via the earth... Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 23, 2012 Author Share Posted September 23, 2012 What would happen if they had no feed? would they stay open? Quote Link to comment Share on other sites More sharing options...
David P Posted September 23, 2012 Share Posted September 23, 2012 Two of the three wires wrong on the MAP sensor would hold the injectors wide open. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 23, 2012 Share Posted September 23, 2012 What would happen if they had no feed? would they stay open? er.. no feed, no power, no injectors! - - - Updated - - - like others have said - take a look at the map sensor Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 23, 2012 Author Share Posted September 23, 2012 Well they seem to be open, just tipping as much fuel into the engine as the fuel pump can send. Quote Link to comment Share on other sites More sharing options...
